I guess I should have sacrificed a few more virgins, bloody rain.
Had a little fun with Abo bob and his 4 doors, sorry mate. :mad:
Did a PB in my sled 13.442 @ 107 mph, but a slow 2.17 60' time.
Gotta get that sorted. :)
Well done to Mona with her new tune and Daniels RNMENC.
Yep, good run Mona.... the 11.75 was nice from Daniel as well... Man thats a big turbo under ur bonnet... did a mini commando roll and sussed out whats under the bonnet while u were adjusting ur coil overs :(
  • Replies 71
Posted Images
I should have asked someone to take a pic of my burnout.
I just went for a little drive to release some pent up energy and log some data. The removal of the radiator air flow panel has definitely defintely improved the power. I can't believe I was choking it so badly before nor can I believe the tortuous route the air is required to run to get eaten by my engine.
Hey guys,
I was out there tonight for the first time ever! (I was the one with the blue cefiro), was good to meet some of you.
I managed to get 4 runs, my best being a 13.4 @ 106mph with a crappy 2.4 60 footer. No traction in 1st and 2nd makes things difficult. With some better tyres hoping for a 12!!
Hello
i was at the track 2nite only got 2 runs first was 13.8 ET 116MPH
Then 12.6 ET 118MPH
First run died in the ass
second run Spined in first and second
When i went to do my third run Someone didnt tighten the radiator cap and then temps got hot and i wasnt allowd to run
When i fixed the problem It started Raining
Shit happens ill be out there next week again with the NOS setup and Taller Diff Gears which ill be changing to 4.56 as im only crossing the line at 5300rpm in 4th hopefully will run in the 10z
RNMENC Was going good
Edited by MR331307
It was a fun night until the rain came...... Just turned up the boost and took some fuel out of the car etc and the rain came down hard.
always next week.
Hey saw your car run, have you changed the gearbox over to a powerglide now? Looked to be a fair bit quicker.
Nah just the Jatco..... just finally got it running right. Now I just need to turn the NOS back on and get off the line quicker.....
On my way home my dodgy cressida rims spat two of the nuts holding on of the rim on, it did a bit of damage to my brake caliper and left me stranded for about 30min while my g/f went and got my 18's :thumbsup:
You were getting off the line pretty damn good on the GWH on your way home.... :thumbsup: (I was in the loud white R32 GTR).
Hey guys,
its the taxi!!!
i remeber readin about ur tuning story...good time man...u were gettin crazy wheel spin
i came down 2 talk 2 ya 2 see what u have done cause i did 13.52 a couple of weeks back in my r33 afta yazuz tuned it at unigroup but couldnt find ya
is urs rb25?? standard turbo?
anyway thats what i have
You were getting off the line pretty damn good on the GWH on your way home.... :D (I was in the loud white R32 GTR).
HAHAHAHAHA it was like a lemon on the way Home... Had the airbox back on and would only rev up to 5000rpm..... But it went pretty good and stayed in a straight line in the wet :D
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
