Hi guys and girls thinking about exhausts lately and decided I may need a higher flowing exhaust any ideas or suggestions would be great
prefer at this point not to get get a off the shelf Jap 90mm as its a bit out of my budget, 2nd hand jap would be fine but maybe hard to find?
Brett
Brett
Brett, an off the shelf jap system will probably be cheaper than a custom made one. Trust do one (TR) from memory, but it's super duper loud (but you wouldn't care about that :) ). It's only mild steel so not too exxy.
hahaha thanks Mik
TRUST do an RO...standing for Race Only...its what Stacey's grocery getter has on it....it even has a little section that you can pop out and fit a cat if you please.
mate whats it like with the silencer in
brett, without on the GTSt it did 109dB
with it in it knocks off a HEAP of dB - I reckon it's around 96dB with it in.
it drones a bit on the freeway without the silencer, but with the silencer in the exhaust is very streetable.
ive got the twin 2.5" system after the cat, back to 2x 3" mufflers. It runs no cat, just a 3" front.
Its a damn quiet system, and doesnt drone (made out of ms, as well as splitting it helps)
2x2.5" pipes equal about the same area as a single 3 3/4" pipe.
It fixed up my flow dramas behind the rb30det. Even Cubes says its a damn quiet exhaust for what it is.
Edited by Bl4cK32
are there any centre muffles/resonators in that system marcus, or just the rear can?
HKS have some nutter exhausts.. my brother has an old Hi-Power (?) one on his 32 that is 3.5" straight through to a 6" cannon.
These days their Titanium Racing Muffler uses 102mm diameter piping :)
Cat back my dump pipe is fine hahaha that sounds so wrong
With exhausts will say a twin 2 1/2" exhaust flow more then a 4" to me it should as you've got 5" of exhaust flow but Im probably wrong hahaha
Your wrong :P at a guestimate, twin 2.5 inch is about the same flow as a single 3.5 inch pipe. (I could work it out, but too busy) It's all about the surface area. Think about how many 2.5 inch pipes you could fit inside a 5 inch pipe.
That TR is the one I was talking about...very loud though.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
