Yeah would work, I personally don't like that one myself and I normally use the one below, don't know why just prefer it over many of the others, just remember clean both surfaces well with carby cleaner put a thin bead around the aac valve let it dry for about 15 minutes finger tighten let dry for another 15 minutes then tighten her up.
http://m.supercheapauto.com.au/Product/Permatex-Ultra-Blue-RTV-Silicone-Gasket-Maker-Multipurpose-95G/5352
Just completed this....took a newbie hour and a half. Car is a lot smoother both when accelerating and standing still. Seems to have removed the engine hunting issue.
One thing I did differently was cleaning the insides, spraying wasn't doing much so ended up filling a bowl with the cleaner and letting it sit for 5 minutes. Also the gasket was in pretty decent condition so just used the same one.
Thanks for awesome walk through! :yes:
  • 1 month later...
  • 3 weeks later...
I've been having a few issues with my car recently in the way thats it seems sluggish and hesitant through the rev range specifically between 2-4k
I recently adjusted my AAC valve before reading this without first unplugging the brown plug (rb20det) could this be a cause to the issue, maybe I adjust it too far or something? Ideas?
  • 5 months later...
  • 8 months later...
  • 2 years later...
  • 11 months later...
Hey All,
First of all good write up!
Has anyone ever had an issue where they have cleaned their IACV and then put it all back together to have a ticking noise from the IACV? Seems to only be present when revving the car and sometimes at idle. I've made 100% sure it is coming from the IACV by unplugging the brown connector, seems to stop straight away when unplugged. Let me know guys, it's doing my head in.
Dan
So I'm stumped... all of a sudden my idle hangs at around 1400rpm for about 30 seconds before it drops to it's set idle of 900rpm, cleaned aac valve and tried adjusting etc etc with no luck, any ideas?
Hi All,
Per my last post, I think the issue maybe due to frequency setting on my Wolf 3D V4. Did some more searching online last night and read that someone has a similar issue to me but in a Haltech.
https://forums.haltech.com/viewtopic.php?t=11221
Since I don't have the hand controller or the cable to connect to the Wolf, I may have to give it in for a tune.
I'll update once I have more information.
Dan
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
