I know a lot of guys don't like using the original setup of using intake vacuum to act as a pump to draw out the crankcase pressure but for me, it is the best way to set it up.
The claim is that it somehow reduces the power of the engine, I would need to see proof to believe that but I'm sure there is a bit of merit in it.
When I got my car, the catch can was vented to atmosphere via a filter on one of the inlets/outlets and the intake pipe inlet was blocked off. My car would get blowby when it was cold and would blow smoke out of the exhaust about 5 minutes after starting the car. As soon as I re-plumbed it back to factory, no more blowby (and associated horrible fumes into the cabin) and no more blowing smoke.
With the engine I'm building now (30/26), I've had two fittings welded into the sump, one to equalise to the back of the head (aka head drain) and the second one will go to the catch can. My can will need 2 inlets (rockers and sump) and one outlet to go to the inlet pipe. I'm assuming (and hoping of course!) that this should be perfect.
Anyone have any feedback on this??
Well, nitto oil pump, block one and 1.5mm on my rb25det didn't last 30mins on dyno, seized the cams
WHAT????????
really? break cams or just damage journals? thats crazy, was the restrictor smashed in when it got hammered down?
Did the cams caps get tensioned? And what tension was it?
  • Like 1
WHAT????????
Yep, got the call from the tuner, he was putting some ks on the motor running it in, revs started to drop and car shut off, try to crank it over but it turned as if it had something seized in it, try to turn it over by hand and couldn't, thibk the tuner is going with seized cams coz of that tapping noise it had and was thought to be lifters
Won't find out the damage till I get the car back and start pulling things apart, 30mins of its life and its already dead, over it
Sorry I wrote it wrong. It's to relieve pressure from the sump. So basically I have 2 lines from the cam covers and 2 lines from the sump that run to a catch can that vents to atmosphere. So I should look at running a second can that is an oil air seperator then plumb that back into the turbo side?
Wow...something not right there. I've got a standard pump with one blocked and 1.5mm and its going great. Hope it isn't too bad!!
The reason people go away from factory crankcase ventilation systems is that it does cost power...but for a non-obvious reason. oil mist, when ingested by the engine along with the fuel-air charge, causes an effective octane rating decrease (ie, it makes the engine more likely to ping). When people startto push lots of boost into engines they tend to get more blowby and more oil mist. That is a no-no when you're pushing the engine closer to the edge of pinging anyway, let alone having more oil mist getting burnt as well.
That's what I am going to do. However there is so little coming out of the cam covers now that I will plumb them direct to the second catch can and leave the first one just for the two lines from the sump (and breather to the second catch can).
sucks to hear man. So for 30 mins of running (idling?) it just conks out all of a sudden? Tuner was obviously monitoring temps and pressure?
It was sent to tuner for run in tune, he started off with it idling checking the timing adjusting the cas, then I left, then got informed of what happen, he was making a new map for this tune so was getting everything ready he said the highest rpm they got to was 2500rpm it shut off on idle they said, it had a tapping noise in top end from first ever start up was thought to be lifters havnt self bleed yet turns out it was more then that to have the motor lock up
From what they telling me it just started to die down in rpms, try to restart it and
Nothing wouldn't, thought it was flat battery put jumper pack on still wouldn't move, try to spin the motor over by hand and it wouldn't move
Yeah tuner said oil pressure was fine, and has said with the amount of noise the head had and we all thinking it was lifters he said its more then likely lack of oil to the head resulting in this
Edited by mickr33couple
Sounds like bottom end. The timing belt would probably slip teeth on the cam but still turn over if it was being cranked over with a jumper battery!
I could be wrong however. If the timing belt was super tight possibly not.
Who built the engine?
Nah motor wouldn't turn over with jumper pack, and timing belt was tight could hear it when it was running, it had good oil pressure alround, I'm thinking block wasn't cleared out the best and there is a blockage to the oil feed to the head, with a block and 1.5m restritor should be able to see a fair bit of oil in the head still,
Won't name names of the engine builder yet till I work out what happen, have spoken to the engine builder he says if cams seized it will be from no oil which he didnt wanna restritor in the first place also said if bottom
End is seized to bring him back the engine to pull down and see what went wrong
It wouldn't take a very large particle to block a 1.5mm hole. Sorry to hear anyway Michael.
I am heading down a similar path with a blown Evo motor (going 2.4L stroker, self built), hopefully it's oil feeds are clear and the bearings aren't too munched...
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
