post-16324-1143457856.jpgpost-16324-1143457715.jpghey guys
im getting my 32 gtr painted next month and really not sure what colour to pick its ucurrently black and iv got three colours in mind
mdnight puple 3 , the 360 spyder ferrari yellow or jet black with a pearl
Hey
I'm also considering getting my R32 GTR painted
I've always thought that lighter colours look best on the R32
I'm going with yellow I think
Will the underbonnet and inside the doors etc?
If the answer is NO then i'd simply go with the same color as the original but with a nice pearl in it....
Having a Black exterior and blue under bonnet isnt a really good look
just like R33_STEALTH said, if your not goin to get the engine bay, underbonnet, doors etc painted and your only gonna do the exterior painting then go with your original colour. The last thing you want is popping your bonnet to show people the engine bay or opening the door and for them seeing you didnt do a full respray, by seeing your old colour underneath. It doesnt look good and you will be called a "povo" or "tightarse" :D
i got everything except my engine bay painted. my engine bay colour is black so i guess its not too bad, noone ever says anything. i actually had someone looking at my engine bay and ask "so what colour was it before?". i thought it was pretty funny.
ali-turko wrote:
im planning on the whole car been painted
Faarrrk!!! The WHOLE car? ...as in underneath bonnet, inside doors, underneath boot lid, engine bay...?
Thats a MASSIVE job! The car has to be stripped down to a rolling shell pretty much. Motor has to come out and engine bay cleaned and prepped. All the doors have to come off, as well as door seals and trim too. Interior has to come out(And im not just talking about the seats!)
I dont see it costing any less then 5-6K
Yes doing the whole car is a MASSIVE job.
Since your car & engine bay is black its better - its alot more obvious if you have it resprayed something like red and inside the bay is white.
if this helps
www.modifymycar.com
you can choose wat car you want (called skyline coupe in it) choose the rims you have and lower it to your specs and change the color and see which 1 you like best.
hope it helps
I'll be getting my 32 gtr resprayed soon too. Anyone got any pics of a yellow 32 gtr? I can't picture it looking too good in my head. My 3 main pics at the moment are bayside blue, dark green, or the new Mazda 6 phantom blue (green pearl).
Yellow?? wtf?
I think thats one of the poorest choices for a car (no-offence secur1ty)
My 32 is black, but when the previous owner chose to get it resprayed he had it done black again (thankgod) with a blue pearl and a small metallic fleck.
It looks black for the most part, but raven blue/black in the sun. Its the best option as you can get away without doing door trims, and engine bay without noticing.
Yellow?? wtf?
:werd:
Morgs painted his car dark green, very close to the dark green Subaru colour. Looks great.
If you're after a yellow GTR, Stirlo_GTR has one for sale that he painted Modena yellow. After seeing pics of R32s in Bayside Blue, I agree with the guys that suggest a dark colour. The black with pearl sounds very nice.
2.2c
There was this purple R32 GTR with the plates GTR or something like that in zoom [not a feature car but a write up on a track day]
The puple was dark but with a pearl. It looked much like that green in the link above but electic purple! i'll try and post up a pic if i can find it
Any way.... a dark colour is good on R32 GTR
Just make sure you have a couple of clear coats so get that lovely "sheen" on it!
I always like the VT SS common-hore blue.
My 2p
Edited by NAman
i must be boring as i have been thinking about gun metal grey for my GTR. (currently also gun metal grey). possibly with a little metalic in there. and of course plenty of clear coats.
question: what colour pearl would the colour coordinated reccomend to go over gun metal grey?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
