  • Replies 126
Frank's best is still in the 1.20's I believe. But he ran that in 2004. Last year he did his clutch straight up and never beat his 2004 time.
Given no problems he'll kill it this time. Last year Sandown had 3 cars under 1.20. Sam, Benno and Clayton.
What about ur session in my car with the semis for the 1:23?
Yeh, id love to...but like i said, when my car finally gets back on the road, it would be nice if i didnt have to go shopping for another $1400 set of tyres. Plus, if somehting lets go on your car, or sh1t happens then id cringe at the cost pf fixing another persons car. I still say my car will doa 1:23 with the diff fixed...so cant see why your car wouldnt do a similar number with the right tyres
Which isnt that big a worry, but i suspect its also the brake it you buy it rule....which if you are pushing the thing to do a sub 1:25 then you will have to giving it a bit of a go...and i dont like brakign my own car let alone others...so its lookign doubtful...
April 25th for those wondering the date. ANZAC day.
Those cheap Brembos look the goods. Wondering what temp they will catch fire at.
I was offered complete Falcon Brembo front and rears today with discs. $2K
May be available to flag. I'lll let you know James.
LOL...if i could work out how to mount two sets of calipers i would run twin std calipers on my rotors though...lol that would look tough, twin 4 pots on the car...Bathurst Enduro spec :P
Dane...can i ask how much the Evolution is? Is it carbon or fibreglass?
missed this post entirely!! :D
The evolution I was looking at is the normal fibreglass one, and it was $1425, and the carbon one is about $2800 from memory.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
