Just Jap Racing is please to bring forum members these fantastic new deals on our new proven and popular G4 Racing Brake Upgrade kits for all popular Import and performance vehicles.
PRODUCT INFORMATION
The G4 Racing brake upgrade kit is an uprated 8 piston front or 6 piston rear end braking package, designed for heavy duty street and demanding circuit or drift competition use, and is the ideal choice for individuals that require heavy duty stopping power at a realistic price point.
Sold as a complete bolt-on kit, G4 Racing Brake packages are manufactured to the highest standard, using quality Japanese pistons and caliper seals, combined with race quality components throughout.
Replacement brake pads are widely available for these calipers, unlike some other large brake upgrades. Almost any high performance aftermarket pad design for an AP Racing 6-Pot caliper can be used with these G4 calipers, including pads from the likes of Endless etc.
G4 Racing Brake Upgrade kits are available for all popular Japanese import and European vehicles and all kits sold include a 12 month replacement warranty.
FITTING REQUIREMENTS
* 17 Inch Wheels or larger are required to clear the 8-Piston front calipers
G4 RACING FRONT BRAKE UPGRADE KIT CONTENTS
  • G4 Racing lightweight alloy 8 Piston front brake calipers
  • 330mm or 356mm 2-Piece slotted brake rotors
  • Caliper mounting brackets
  • High performance brake pads
  • Braided brake lines
G4 RACING REAR BRAKE UPGRADE KIT CONTENTS
  • G4 Racing lightweight alloy 6 Piston rear brake calipers
AVAILABILITY
G4 Racing Brake Upgrade Packages are readily available for the following makes and models:
- Nissan Silvia S13
- Nissan Silvia S14
- Nissan Silvia S15
- Nissan Z33 350Z
- Nissan Skyline R32
- Nissan Skyline R33
- Nissan Skyline R34
- Subaru WRX GC8
- Subaru WRX GDB
- Mitsubishi EVO 4-8
- Mazda RX7 FC3S
- Mazda RX7 FD3S
- Mazda RX8
- Toyota MR2 SW20
- Toyota Supra JZA80
- Ford Falcon BA/BF
- Holden Commodore VY
- & Many Many More!
We have a number of these kits in stock ready for immediate pickup & dispatch, so unlike other deals floating around the net, there is:
1. No deposit required
2. No minimum order
3. No waiting
4. Easy online payment options
5. No surprises
Deal with an established and trusted company! - Not a backyard trader
G4 8 PISTON FRONT BRAKE KIT FITTED
PRICING
$1999 - 330MM BRAKE KIT (FRONT OR REAR)
$2199 - 356MM BRAKE KIT (FRONT OR REAR)
IN-HOUSE FITTING AVAILABLE FOR SYDNEY CUSTOMERS
HOW CAN YOU ORDER YOUR KIT?
The answer is simple!
Visit http://www.justjap.com/parts_nbraking.htm and purchase your Brake Kit online, quickly and easily via paypal or credit card, or drop by our Kirrawee factory and pick up a set over the counter.
Please contact our sales team if you have any questions, or reply here.
Dont forget to check out our huge range of new and used performance parts and import vehicles via our website at www.justjap.com
  • Replies 59
Hi mate, I have updated the first post.
They are only available in the one caliper colour at this stage and they require 17 inch wheels or larger to accomodate the large 8 piston calipers.
Regarding fitting, they can be installed with relative ease, and though we dont offer a fitting service in house, any competant workshop can fit this kit up for you.
Cheers,
Steve
Hi, I'd like to know if the pad pattern is a commonly available one or if it is proprietary for these calipers. Thanks
Hi mate, the pads for the G4 Racing calipers arent proprietary
There are a number of aftermarket brake pad options available from the likes of Endless etc, and these G4 calipers use the same pads as a common AP Racing 6 Pot caliper.
Cheers,
Steve
They seem to have similar design look to a Tarox kit. Can you give any more info of the history of the caliper and rotor...do they work with the std rear brakes and master cylinder?
Hi Roy, the G4 calipers with work fine with the standard master cylinder and rear calipers, we have tested this on a few of our customer cars.
The actual design of the caliper is based on an AP Racing caliper and they will use most aftermarket performance pads designed for an AP 6 pot caliper ie Endless.
If there is anything else you would like to know, please feel free to ask
Cheers,
Steve
Do you know the piston sizes. Also how much are just the calipers on there own incase I would like to make adapters and run bigger disks (355 or bigger)
Hi Rowdy, I will check and see if we can source the calipers themselves without the rest of the kit.
I will also check into the piston sizes and confirm as soon as possible.
Cheers,
Steve
great looking kits, well done getting them at this price :D
can you post a pic of the adapter for the caliper?
do the standard gtr brake lines bolt straight in?
what are the other dimensions of the disc (do they match any local or DBA sizes?)
Yeh very interested in the width of the rotor, and how readily available replacement rotors are. Do they match the PCD or other aftermarket 330mm rotors or would changing brand of replacement rotors dictate a new hat?
Hi Roy, the majority of the components in the G4 kit are interchangable with components from AP Racing kits so replacement rotors are not a problem.
We measured the rotors today, and they showed a thickness of 32mm and an actual overall diameter of approximately 331mm.
Cheers,
Steve
Do these require caliper adapters, or do they bolt onto the stock holes?
Can you get them for an EVO 3?
Each kit comes complete and ready to fit including adapters.
Unfortunately G4 have kits for EVO 4-8 only at this stage.
Regards,
Steve
Gday Duncan, the GTR kits include new braided brake lines - We would need to check if the original GTR brake lines work go back on.
As per the post above, the discs are 32mm thick and as with the other components in the kit, are very similar to those of the various AP Racing brake packages available so availability of replacement components is certainly not a problem.
Lastly regarding the adapters, I dont have a pic of the adapter itself just at the moment.
Cheers,
Steve
These kits are selling quickly and generating a tonne of interest at this price.
We have plenty of kits available, so place your order now.
Any questions? Please feel free to ask.
Cheers,
Steve
could you please tell me the part numbers for the pads that fit. endless etc. etc.
Hi mate, I dont have a listing of every part number for all the different pads that fit in front of me.
If you would like further information please give us a call in store on (02) 9545 0532 and speak with Darron and he should be able to look up most of the information you require.
Regards,
Steve
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
