I did this fix to my GT-R about 8 years ago and it hasn't missed a beat since.
At the time, I wrote it all up but never got around to putting it up online.
One thing I would add is that I also found bad solder joints on the AFM board itself. Once I had the lid off the AFM, I repaired these as follows:
- carefully lever the copper cover upwards to gain access to the board beneath (see crappy photo - taken after resoldering)
- the three solder joints circled in red at bottom right of the top board were bad and needed resoldering
- the other solder joints circled in yellow on that board looked reasonable, but I resoldered them anyway
Note: Do not touch the lower board. It has been made using a completely different process (surface mounting) and is much more delicate. It also should not have the problem of “dry joints”.
Good luck!
Dave.
  • Like 1
  • 4 months later...
Wanted to bump this thread as well, because it fixed my problem with my R33 GTR.
My car wouldn't idle properly intermittently, and would sometimes miss, now it runs like dream!
Thanks, it's like a new car now!
My car doesnt rev up to 3k now, since I opened and cheked the AFM's yesterday, didnt do anything or resoldered, but before that, I experienced the same but I can manage to rev it higher just pumping the gas always, but now, I cant rev it high even often pumping the gas, I also clean the fuel filter checked the plugs and coil pack which seems ok. Now I dont know what to check next. Please help.
Had my car diagnosed and found error code 0012. w/c is AFM . So I told the mechanic it cannot be since I think the AFM is in good condition. So he decided to remove the socket while the engine is running and it died. so he ruled out that it might not be the AFM, he removed the silicon rubber inside the housing of the socket w/c is in not good condition and connect it again and whoalla!! It run as normal condition, we decided to diagnose again and the error was gone but another came out w/c is code 0055 (condition normal). we checked the code error here in this forum and it was listed "No Malfunction". I will drive test it later just to be sure!!
Great help on this forum!!!
  • 1 month later...
  • 11 months later...
  • 1 year later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
