They are stainless still and aren't painted.
The dude that made it is a douche. He has been in so many failed car making projects. He really needs to give up, I mean the guy hasn't contributed anything to the automotive world but he manages to find work or inverstors and makes crap cars like De'loreans.
I think you'll find that he 'gave up' a year or so ago...
I had alook into these a while back and was not impressed by the overall concept.
They are an 80s car with all the imperfections of that era, theres a mob in the US that can offer any type you want from basic stock to fully stripped and improved everything that is know to go wrong.
The only thing they have going for them is they are rare and collectable, I dont think they would loose value now.
One of the biggest drawbacks are the stainless body panels, as the repair of them is nigh impossible to get that straight look again and is cheaper to buy new panel even at todays prices, or paint the whole thing, which is an effort if you have ever tried to paint stainless properly.
Delaoreans were meant to be like proper supercars.. but they ended up with a V6 and a f**king heavy body :S think about it, how would you get out of the car if you flipped it?
if you managed to flip a 2 tonne car i dont think you'll be getting out of it.
I remember when these were first released, delorean had a lot of car makers running scared with his ideas.
"A car that could last a man a lifetime", imagine that!!, great for the environment, not a bad idea...especially in the disposable 1980's. Add some rumoured industrial espionage and it's a very interesting history for a very interesting car.
It's a shame that manufacturing costs and the price tag were so prohibitive.
@ 55k it's a worthy investment and at when peak oil hits us at least you'd have something with a decent scrap value :bunny:
Oh and sif paint stainless.....just hit it with the buff, beautiful.
Stailess steel! f**ks sake, does it come with a sink in the boot and a chopping block?
Nope doesn't come with either of those...nor does it come with rust...ever
It's little wonder the big three made sure he failed.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
