OUCH!
and oi Chris.. You might provide the cable ties, but remember I'm the one that does the tieing! :(
oh, and I'm with thomas RB26!
This is a VERY complex discussion that can go on for ages, and will surely piss the rest of the whores off if we discuss it in this thread, but in a nutshell, all things being equal, a normal stroke RB26 is better for big power on street fuel than using an RB30 crank for the following reasons-
*The piston speed is lower at the same revs
*There is less side thrust exerted on the bores by the pistons, due to less conrod angular/side motion (less heat/friction)
*The Piston spends more time in the dwell state at TDC and BDC
*The Bore/Stroke ratio is much better (over-square engines like to rev harder)
Which helps, briefly, with the following
*Keeps frictional losses down (engine lasts longer, makes power more easily)
*Helps secondary balance
*Optimises manifold air speed at high revs
And blahdy, blahdy, blah. [/end rant]
Nissan could have made the engine 3L if they wanted to, but they didn't.
P.s 2JZ's and RB30's both have around 6800rpm limits from the factory, which is the same piston speed as an RB26 at 8000rpm.
  • Replies 240
Ouch... how much damage to the head (esp the combustion chamber on 6)?
Pretty respectable effort, haven't seen something that smashed for a long time!
Edit - that quote from R32R at the top of the page is wrong, very very wrong. I think he's got things crossed up.
That's what I thought too but I'm glad somebody more knowledgable than me said it first.
But but but, if RB30 bottom ends are so good, then why can't I get a crate engine with an RB30 bottom end shipped from Japan? (innocent look)
No one will do it for me! They all say something along the lines of, "Are you stupid?" (innocent look)
(...stupid for asking them to build it, not stupid for asking them to build one and send it)
Seriously though, I'd like to hear someone that is all for RB30's tell me why they're better. I have no idea.
..uhm..so as not to hijack mona's thread, this is for your benefit too moonie :huh::(
i've heard RB20DE
It will be sweet when it has the CA18DE in there, should be an animal,ooops I've said too much.........
Personally, I'd be going for an L16 and turbo, blowing through a decent sized carbie of some sort - 45mm Weber, Dellorto or SU, side-draught of course... :huh:
im sure u can cable tie it back together.. no biggy
Bit of gaffa tape and she'll be all good again..
Ahhh, cable ties and gaffa/electrical tape - the drift/drag/circuit racer's and mechanic's best friend! :(
Seriously though, that is some heavy duty damage. :rofl: Mona, you should keep the parts and display them somehow for memories. Ahhh, the good times!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
