I nearly shat myself first time doing 170 or something on last track day coz it felt so close to the wall :P Probably on one ocassion I did 180 but all focus was on the brake at that moment. Beside having fun I still intended to drive the to work on Monday so . . . :P
  • Replies 234
Posted Images
Well Paul I reckon I would be in this one. Just spoke with GTR Jason who nearly has his R32 GTR going to finally get out and give me a hard time. He said he will push to have car ready for this one.
yeah true, but i dont know that an auto 33 will even hit 180, and being first time out he will be hard on the brakes bro! on the brakes! at the kink :D
good point though, just be aware of it wink, but dont let it stop you.
*LoL*
Not much chance of making the turn/stopping in time for the next corner if you don't ease off a bit at the kink.
depends what you driving. would you believe me if i told you that an S13 running a stock motor, stock turbo, stock intercooler just big oil cooler big rev limit and big boost can do 1:20 flat around the GP circuit with 2 people in the car (one of them over 80kgs!)? and i can tell you he's not braking (much) before the kink! personally i'm braking well before it.
*LoLz*
Yeah...me too. Don't have quite that level of commitment on Ziex's :D
Plenty of room too improve on my 1:27, then.
well part of it has to do with no straight line speed, a more powerfull car arrives there much faster and need to brake. but he had the combo of:
light car
good suspension
no power
huge nuts
so can carry maxiumum speed through there, then hard on the brakes for turn 2. he certainly taught me a few things. he is pretty much as quick around GP as GTR jason (400kw track only GTR with dog box) and a guy with a GT3 porsche and john etc.
Respek :angry:
I think you summed it up well.
Light cars with good suspension/chassis and tyres will always have the advantage over heavy-ish cars like GT-Rs as far as ultimate cornering speed goes, and like you said, he probably doesn't arrive there with quite as much speed anyway, and being light, the brakes have an easier time into turn 1, too.
Prolly explains why Fatz could manage a 1:29 in an atmo RB30 Silvia, and I only went 2 seconds better.
i am keen to come to a track day and the first and only track day i did was a when the fats day was on the the main track, i was in my lil NXr coupe, now i hope to do alot better in my 31, i just got to get the day off work, and pehaps ask my boss for any slicks from his raceing car he dose not want anymore :/
hi never done a track day but am interested,what would tyre wear be like on road tyres ,would i need a new set after the day?
slight mods with 290rwkw & ohlins suspension all round
not aiming to drive the tyres off it, but have heard that the track eats street tyres!
guys this sounds great. I have been planning to do this sort of driver training/ track day for a while now. Never been on the track before though. Will there be at least some beginner level training with the instructors?
Overall the day sounds great ill arrange day off and send application if all goes well.
hahah pete we saw yuor lock ups after trying to flat thru the kink.....skylines are just too fast to pull that trick off without great tyres.
but the mighty woos used to be flat thru there, led to some HGE offs there sometimes
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
