I really like the beach idea, OBH is good and there's plenty of parking. York's museum is quite small and there really isn't much to do other than the nice drive up there. Perhaps a busselton type beach if you want to go for a long cruise?
or broome
Nah to far. . . a few hundred ks less, there is a place called karratha. If you cruise up here have my place as a meet point and ill supply everything for a bbq my shout. I got spa too. . . that always equals points + + + +
:thumbsup: Oh and ill supply the beer too
Well if you decide to out to York, plenty of redneck farmers with shotguns around.... So I guess there is no need... :thumbsup:
Errmmm... Why not take a cruise down towards Mandurah.. Mandurah is nice...
does anyone know when this cruise will be held because id like to come too, just need alot of notice so i can book holidays and drive down to perth.
Also wanna take my car to the drags to see what it does while im down
  • 2 months later...
Ey random idea but interesting i think :P
what about north to south doing a few freeway runs looking at Christmas lights ??
plenty of interesting snobby suburbs to annoy :P
+1 for good idea
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
