  • Replies 257
Posted Images
Being part of the QLD skyline family, I will put $5 for SKA's fuel as well ( I dont even know him though, ya, I am new here.....) ANyway, getting really exciting, by the way, smooth, can my number be 26? since it's my lucky number, hope it will bring me the big surprise, haha!
Far out, just goes to show you how many great people there are here on SAu!
Total: $58
I'm in pending date
any more clues as to what actually happens here?
am i joining a pyramid scheme?
cheers,
Warren
To put it simply:
-There will be a meet
-THere will be a surprise
-There will be a drive
-There will be a final suprise.
Everything will be revealed on the night...
We're all forgetting he moved up the coast to earn eleventybillion$$$$ I *remove* $50 from Ska for the pure cheek of the fellow!!!!! :thumbsup:
good point!
can we use the money for a stripper as the end surprise instead?
To put it simply:
are you sure you dont promote big brother on your days off???
oh, forgot to say, ill throw in 10 for cyrus as well
my goodness the shennanigans of old times... im scared already lol.
Last time we both had rwd cars and the stats were 2 to 1 in my favour.
This time we both have awd, be interesting what the stats would be :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
