I have never actually been "ripped off" on ebay, you just gotta be aware of the fake copies going around nowadays.
I bought a "Blitz" pod filter. When i got it, it was a supercheap pod with a blitz sticker on it.....
Check the sellers rating and feeback.
If your buying something for your car on ebay and its a "China" copy, make sure it has no moving parts.....ie steering wheel vs a turbo.
bought a clutch kit of a guy on ebay for my excel
no worries
shipped in 3 days (and that was from over east over the weekend)
cost me $160 plus shipping (my mechanic reckons that they are bought $200-300 from hyundai)
but yeah - check the trader rating etc etc, if its a shop its usually a little bit more reliable - so see if u can get the shit thru a ebay shop
Yep the posts above sum it all up. Buying stuff off ebay comes down to checking their trader ratings and where possible avoid items that need to be well engineered as there can be a lot of fake stuff on there (if a trader has an excellent rating and feedback it can be worth giving it a go.)
Good luck.
bing...i have bought from rims to exhaust canopies for the kitchen....alll good
check traders rating... read all the crap they stick in the auction
look carefully for wordplays as well.. some auctions are worded to screw you
just be cautious
if its too good to be true.. it usually is
i got screwed on a turbo . matey said it was a t28 in perfect condition where in fact it was a t2 that was shagged . had big slagging match with the bloke after we left bad feedback because he wouldnt answer emails. eventually had to get a refund from ebay after proving that turbo was crap and worthless. thanks to HYPERDRIVE for their help.
matey on ebay has done a runner.......also threatened to beat me up even though he was in brisbane.......and im in perth.
kermit
and *always* check cost of postage, some gear maybe cheap, but they jack up the cost of postage.
i had a win on ebay the other day with getting a full set of potenza ajustable dampening shockies with lowerd springs for $100.00 with $25 postage, but cost the poor guy $137 to send it to me. if you are out there know they have gone to a good home.
WTF ?? That's CHEAP !!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
