Yeah 100% the actuator mate, dropped the exhaust and took the car for a spin...sounded tough but boost still faded away.
Putting a bellmouth dump on tomorrow in the hope to equalize the back pressure accross the wastegate flap and stop it being blown open by the low pressure that's currently sitting behind it (the split dump is split too well)
Possibly but I doubt that is your problem.
Did you say the turbo only made 15psi with no vac hose attached to the actuator?
Have you taken a boost reading from straight after the turbo and then another one from before the t/body, then another one from after the t/body?
If not - do that.
Skyline is basiclly sold now... :thumbsup:
Got a car yard to put an offer on it, so now I have a week to try and sell it for more however I dont think it will as everyone are tyre kickers these days...
Im asking a grand more that the car yard has offered, and its gonna cost a grand to put it through road worthys and mod plates...
So im not holding my breath...
Thats a pretty good price from a car yard.
In this market i would take it. Like you said a lot of tyre kickers about.
Skyline is basiclly sold now... ;)
don't take this the wrong way, but all that to achieve 300rwkw and not to really use it?
like you said, there's a valid reason: owning too many cars and hardly driving it.
and i'm speaking generally here; but doesn't anyone plan things anymore?
why i want the skyline?
what i want to do with the skyline?
how am i going to achieve the above?
just seems a shame that's all. alot of hard work and no enjoyment.
If not - do that.
lol yes, and the fact you can watch the actuator open while on the dyno is a bit of a giveaway. I'm not your typical SAU n00b Dan ;)
howly dooley you boys get active at night!
ok this is the best I can do for you:
Had the car for 6 months, purchased from dodgey import yard. 90,000kms on clock Possibly original timing belt - this worries me!
Fully stock trim apart from turbo back exhaust and apexi pod filter
Car has always run like shit when cold cofs and splutters when you give it a bit of gas has been known to stall from time to time
when accelerating it will sometimes misfire and backfire
Has started to use lots of fuel recently
On sat night we went for a spin, driving the car hard once it was warmed up was going nice
Launched the car from the lights apparently did not feel it had as much go as usual - kept pushing anyway
Drove at normal speed for a couple of km
Decelerated to a set of lights
Engine cut out
Refused to start
Would not turn over
basically just: kik kik kik kik kik pop pop kik kik kik kik pop kik kik kik - pit of smoke coming from exhauste - not puffing out more like smoldering out
RACQ Checked:
Fuel pump - good
Alternator - good
Dizzy, Leads - Good (Changed leads last service)
Oil good was changed Saturday morn with Royal Purple and KnN Oil Filter
Apexi Air Filter was cleaned and re-oiled on Saturday morning - he is woried he put too much oil back in as there is a little dripple of oil in the bottom of the induction pipe - should this be cause for concern?
Found the plugs to be soaked in fuel after trying to start it so engine is getting fuel - mabye too much?
feels like maybe a computer issue or another mate reckons he snapped his timing belt - this idea was thrown in at around 10pm last night and has not been checked yet, will keep you posted
is it normal problem for gtir to run like shit when cold?
thats the best I could do as its not my car but I have a decent understanding on how its been playing up!
Thanks again markimak!
if the timing belt snapped, the motor would be completely shagged, i.e valves contacting pistons = valves through tops of pistons :glare:
GTiR use timing chains. and ther will be no crank over at all if the valves are hitting the piston.. i might come have a look wher u located..?
the timing chain is alot stronger (opinionated) than T belts. and dont need changing.
check how much oil u have. perhaps ur mechanic forgot to tighten the sump plug and ur oil leaked out.
sounds like its cranking over. so im guessing its gonna be no spark. they check ur ignitor.? get a compression test
all cars run shit when cold. its just they run a different map and have the auto choke on. u shouldnt drive a car hard untill it reaches operating temps.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
