I didnt actually call Chris... I just knew you were not telling the truth...
He is actually going to work for Chris Rogers. I had to buy him a $200 Snapon soldering iron on Wednesday coz he didn't have the time to get out and buy a decent one for himself. I thought he was joking too when he told me but it's actually true. Which sucks coz I was gonna take my skyline there for an install but I'm worried he'll power up the headunit from the same wire that powers the ECU :wave:
He is actually going to work for Chris Rogers. I had to buy him a $200 Snapon soldering iron on Wednesday coz he didn't have the time to get out and buy a decent one for himself. I thought he was joking too when he told me but it's actually true. Which sucks coz I was gonna take my skyline there for an install but I'm worried he'll power up the headunit from the same wire that powers the ECU :)
No bs Dan, The ginga ninja starts with Chris on Monday. And best of luck to him is my call. ;)
Arhh well good luck to him...
PS. I sorta still dont believe it... But ill take your/dan's word for it...
why is everyone finding it so hard to beleive
I guess cause he is switching industries, I mean going from drawing and development across to auto-electrical...
It would be like me giving up sales/account managerment and jumping to lets say becoming a farmer...
Although I can see this as being a bit of a seachange for shane and so i can understand...
Nothing against what he is doing at all, i think his passion for cars will be a great advantage in his new role... I just thought it was a bit of a left field move thats all...
Plus the money he can make doing this could easilly outweight his old role, andthe other plus is he will have a new workplace everyday as he travels, that the best part about my job is you get to travel and your not stuck at a desk all day...
Fs 18 X 8 18" Rims With Tyres $750, OMGWTFMAGSAVINGS!
http://www.skylinesaustralia.com/forums/Fs...es-t197551.html
shamless plug GTFO
:banana:
thats it indeed.
i was just sick of sitting in front of a computer all day long being bored with fark all work to do. plus im sick of the office politics that goes on in an office job
No A/C here
Our ducted compressor had to be moved to repair a dodgey retaining wall and the slab will not be getting re-poured till later this week...
So hopefully we will have our A/C back by the end of the week... :)
fkn just ot home frm the work krismas party its bloody hot in my room aye cranking the air con right now!!! 4 hrs till i gotta be at work but im charged atm! dout i will feel the sam when its time to get up tho...
well i made it to work although I feel as though I have been eating sand while someone rubbed my eyes with steel wool
this looks to be the start of a very unproductive day...
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
