Bob Jane T-mart $1400 for a set of Yokohamas....place up the road to me $1036!!!!
Why do some places try it on so much???
i've noticed that... my theory is they try to get you to buy the locally branded tyres rather.
$1400 for yokis? or $800 for dunlops... you get the idea.
Just thought I'd remind you all that:
you are from QLD and you lost the State of Origin
Losers
P.S. People frequently question my sexual orientation
but your states sux ass so much you pretty much all moved up here??
Me too... :D
thats criminal, but in the case where u have to pay that amount anyway why not get the top notch fuels lol pity we dont have v power racing up here much i think only 1 servo has got it, and its not really worth the drive to get it unless u are going racing or something.
i had to fill the bike up twice today... :)
$47 later... damn gold coast hinterland being so biker friendlly on such a beautiful day... :(
ended up doing almost 400kms before lunch... and damn it was cold at 6am this morning... :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
