Its not a gtr.. the guy asked me about my indicators a while back.. also if you look closely.. the indicators on the gtst are more fat compared to the gtr slim and abit longer ones that kinda curve round..
GTR WANNABE
Why lie about something..
Is he ashamed of having a gtst????? thats just stupid.. and if he actually believes that he has a GTR he's either completely retarded and got jipped big time.. maybe he should have read up on it a little better..
hahaha
Edited by Alien
I'm not on his side or anything.. but i remember him posting that he was doing this widebody gtr.. then he had to go buy the gts-t lights because the way the kit is styled it only fits gts-t lights... but meh.. i could be wrong and i have been before..
judging by the threads hes started, it looks to me asif it were a gtr... e.g.
*Knocking In R32 Gtr
*Another 4wd Problem
*O2 Sensor (r32 gtr)
etc etc
this for all the smart asses out there
heres the dirty engine i was talking bout
all the info is there
why would i get my seats embroided with the gtr logo if its a gtst
more info, i havnt put it back in the engine bay, as its just got painted
dont u hate when guys dont no what there talking bout, want more proof come and have alook
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
