That's hot man but your front bar looks warped?
What sizes and offsets are those wheels?
Yeah it is a bit, looks worse because the photo is shot pretty low. Brought two of them for $250 and sold one for $400 so I'm not to fussed.
The wheels are:
Rear - 18x9.5 +18 215/40
Front - 18x9 +13 215/40
took a couple shots this arvo and tonight, heres a few i mucked around with. Hard trying to get them looking nice without going too far :S, not sure if i did or not.
I included a few of the crappy night shots so i can get some advice :ph34r:
post-22805-1226068188_thumb.jpg post-22805-1226068202_thumb.jpg post-22805-1226068215_thumb.jpg post-22805-1226068228_thumb.jpg post-22805-1226068239_thumb.jpg post-22805-1226068355_thumb.jpg
oo very nice!
How did you get your black paint so shiny in the first pic?
The wheels are:
I can't believe you managed to stretch 215's onto a 9.5" rim. No tyre shop I know would do that and I know people that work at one!!
I was running 215/40/R17 on the front of my XD9s which were 17 x 9.5 + 17 and 225/40/R18 on the rear 18 x 10 + 18 :banana:
Some serious stretch
Here's a couple shots of how the wheels sit and tyre stretch, still need to sort front and rear camber. Was running 225/40 before these but they were rubbing quite a bit, might just be the design of the tyre there might be a 225/40 out there that fits a little better.
what size and offset on those rims? look tuff!
Front - 18x9 +13
Rear - 18x9.5 +18
You should be able to get away with that on the back
I had 18 x 10 + 18 on the back of my R32 with 235/40 tyres. The inner lip on the guard was rolled and we slightly pumped/flared the whole guard, not to much but just enough to tuck the wheel under
Fron't I had 17 x 9.5 + 17 with a 235/40 tyre and same deal, guard liner removed with the inner lip rolled and guard slighly pumped/flared
Man, you guys all freak me out with the size wheels you are jamming in under the GTSts. I want to run a 9.5" , maybe 10" rear but only because i want to run a 265 rear tyre :down:
Anyway, the car has 9" +20 offset which should be doable and when the guards have been pumped for that sized rim i should be able to get a 9.5" + 36 on the rear aand run 255 tyres.
Is anyone running wide rims with decent sized rubber?
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
