Rekin, they didnt wet the track down did they? the wet looks uneven.
URAS NS-01's, 17x8/9 +30
the track was sprayed by a truck but due to the hot weather it would dry up before the truck would come around again.
nisskid is right about the rim sizes, afterall they were his old set ;)
Hopefully ill be able to squeeze some 255/40's under the rear guards...
nisskid is right about the rim sizes, afterall they were his old set :)
Liar
You just can't drift for shit!! Your not d1 champion
nisskid , thats some tuff wheels you have there... got urself a gtr hood as well huh.. nicely done
yeh im too poor to afford a GTR one unfortunately, me and my old man made that one, we bent the lip up then bogged it to reinforce it, its nice and strong and wont bend like other people's cut GTS-t bonnets that are weak around there.
mm wonder why they do that, sure it's easier to get it sideways but u dont learn anywhere near as much in the wet as u do in the dry. plus i personally dont think the wet is anywhere near as fun as the dry, but thats probably more a personal opinion thing.
Thanks Excess
and here's another one...
Cheers
That rear bar looks mad!
Thanks heaps buddy!
Liar
LMAO!
Abu you sound a little angry these days..?
You must be itching for a drive in your R33 GTR?
Hey abu, show us your new ride mate !! S13 ??
I think he's still got his R33 GTR.
Thanks heaps buddy!
LMAO!
lol haha na not angry just bored!
I sold the R33 GTR off man, no more GTR
yeah the kent is too cheap to buy tyres so he just gets a new set of wheels
LMAO!
Cheaper to buy a set of wheels with a bit of tread left on it.
Ah really?!
I thought you were gonna keep it and do it up? Whats up next for the garage?
its a vertex Jamie ;)
Yeah thats why it looks mad cuz its a Vertex, love those bodykits.
Or go wider like LEANBAC's BN Sports kits.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
