here is my little project.
this thread is my inspiration.
going slow, trying to get it prepared for paint, best i can with tools i got.
stripped all the paint out, and started from scratch, hopeful to get engine bay and boot done this weekend, and some brackets made to flip it over in the coming weeks to paint underneath.
more info in my garage.
http://www.skylinesaustralia.com/forums/in...mage&id=615
http://www.skylinesaustralia.com/forums/in...mage&id=616
I HATE PAINT...
Edited by 32_Dave
is that the dmax boot spoiler you got on the back?
yep it is. looks pretty neat. i am also going to get a roof spoiler as i dont want to run a GT wing.
As far i i know D-Max stuff is getting scarce as the people i got this off had to change suppliers twice and then it was the only one they had. it seems that there is a lot of issues with D-max aus.
i seen recently that Viva garage sells the roof spoilers cheap as chips. much cheaper than D-max. even thoe the last Viva kit i got was worse than rubbish ill try them again.
well here are some pics of my new gem.. picked her up for a great price off an old mate for 9K as she sits. Former owner has spent over 8K on mods in the past year,
such as but no limited to;
HSD adjustable coil over suspension
Adjustable camber arms
Adjustable control arms
Solid Cradle Arms
(only thing that hasnt been touched is the sway bars.)
18" gold speedy ( Volk GTC copies) Mags
Sandard turbo but highflowed by GCG - Ball bearing 500hp
Walbro fuel pump
Cooling Pro FMIC
Oil filter relocation kit
Greddy Oil Cooler
Greedy Catch Can
Engine Dampner
Strut Brace
Stainless Turbo Manifold
3" Turbo Back Gutted Exhaust
Shimmed diff
NPC 5puck clutch
Short Shifter
ADR approved Blits Fibreglass vented bonnet
It pulled 183rwkw @ 13.5psi and had steady but rich AFRs, I have upped the boost to 15psi and its running sweet yet to dyno it on 15psi yet. I have R33 GTR 444cc injectors and Z32 afm waiting to go on once i obtain a Power Fc for the right price.
anyway here is some pics of my new sex on wheels
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
