32s i found on the net. my 32 is black with stock rims haha
RB20 GT2535 18psi 300whp - the car's 20 years old this month!!! they don't make them like they used-to
ratty drifter, porn
first dibs on this kit if I can find it!
local track radial tyre record holder (in japan) lightened to just over a ton and RB20 with 25 turbo.
cheers
cheers
Front bar vertex
side skirts vertex
and rear bar looks to be final konnexion
vertex parts are easy to get, ive got the side skirts and rear bar on my car
and final konnexion im pretty sure are also avaliable at some of the body kit places to
more details on this thanks.
Cool, I'll do my best but the pics are big as they get on the website I think. I got the pictures from a blog written by Tochi, from shop called YMS. This HCR was brought in by a customer (Super NOW) ‘NOW’ is phonetically spelled for ‘na-u’ (na-u-i), which is ‘trendy’ in Japanese. Who just got the track record for Nikko circuit 38.902 sec for radial tire TOYO R1R (I heard from a local Toyo guy that this is not released as a semi-slick any more, I got them on my car and it’s so soft like a semi ). This car also does the Tsukuba 2000 track in under a minute J sweet.
I read Japanese so I surf the Japanese side of the web.
The blog read something like… the car came in for a check and a possible retune, had the diff ratio changed, different boost controller installed. Base figure was 280hp at the rears, after the tune was 300hp on same RB25 stock turbo on a/m exhaust manifold. And came in later for another tune with an adjustable cam gear. The power was measured by dyno-pack. he might have this thing calibrated to show power at the flywheel, I donno. When I read some of the power figures on his site, all the power readings seems to be high ish. there isn't much info on the site apart from the motor. looks like lexan for glass atleast.
Im putting up all the pics from the web http://blog.goo-net.com/tochi/daily/200909/12
hope you enjoy!
P.S thanks for the kit info
Yeah i also dont rate chromies AT ALL! Your current rims look good on the car though. Black on black can look good but sometimes the rim style is a bit lost cause they don't stand out. But time attack's are fkn sweet!
OOOH those are DAMN SEXY!!!!!!
thanks mate
    • Not that I know from experience, but in theory you'd want your gate spring to be as close to target pressure as possible, so you'd go with the higher gate spring?
    • Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion?   Edit: Actually I might just swap the spring and see what the logs say after another few pulls, as we know it's still spiking without the Mac valve in the picture so I need more data without the Mac valve trying to combat the issue.
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
