32s i found on the net. my 32 is black with stock rims haha
RB20 GT2535 18psi 300whp - the car's 20 years old this month!!! they don't make them like they used-to
ratty drifter, porn
first dibs on this kit if I can find it!
local track radial tyre record holder (in japan) lightened to just over a ton and RB20 with 25 turbo.
cheers
cheers
Front bar vertex
side skirts vertex
and rear bar looks to be final konnexion
vertex parts are easy to get, ive got the side skirts and rear bar on my car
and final konnexion im pretty sure are also avaliable at some of the body kit places to
more details on this thanks.
Cool, I'll do my best but the pics are big as they get on the website I think. I got the pictures from a blog written by Tochi, from shop called YMS. This HCR was brought in by a customer (Super NOW) ‘NOW’ is phonetically spelled for ‘na-u’ (na-u-i), which is ‘trendy’ in Japanese. Who just got the track record for Nikko circuit 38.902 sec for radial tire TOYO R1R (I heard from a local Toyo guy that this is not released as a semi-slick any more, I got them on my car and it’s so soft like a semi ). This car also does the Tsukuba 2000 track in under a minute J sweet.
I read Japanese so I surf the Japanese side of the web.
The blog read something like… the car came in for a check and a possible retune, had the diff ratio changed, different boost controller installed. Base figure was 280hp at the rears, after the tune was 300hp on same RB25 stock turbo on a/m exhaust manifold. And came in later for another tune with an adjustable cam gear. The power was measured by dyno-pack. he might have this thing calibrated to show power at the flywheel, I donno. When I read some of the power figures on his site, all the power readings seems to be high ish. there isn't much info on the site apart from the motor. looks like lexan for glass atleast.
Im putting up all the pics from the web http://blog.goo-net.com/tochi/daily/200909/12
hope you enjoy!
P.S thanks for the kit info
Yeah i also dont rate chromies AT ALL! Your current rims look good on the car though. Black on black can look good but sometimes the rim style is a bit lost cause they don't stand out. But time attack's are fkn sweet!
OOOH those are DAMN SEXY!!!!!!
thanks mate
    • I've got a spare standard box sitting in the garage  I know it will come one day though, but it's driven pretty tamely on the four times a year it gets out...
    • Big question… have you decided on a gearbox? Because it’s going to come… and a gearset ain’t going to do the job.    save your pennies 🤪
    • it was good to see our presence at GTR festival..hope to see more SAU at these events
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
