Haltech, oem BOV's, a re-tune, driver/passenger windows and a engine bay detail this weekend ? OK
sounds good. Ill drop it off on saturday and pick up sunday?
Also prob am detailing this weekend
Yeah mate for sure, when I get back from the states later this year we should get them all together
Definitely! Always good to meet fellow 32 GTR owners.
The gtr in front is mine and behind is my brothers which is a Scuderia gtr. 1 of 6 and his is compliance number 001. Has standard n1 front and rear lip with snorkels, scuderia boot badge, scuderia instrument cluster and scuderia compliance plate as the car came to aust as a low volume import and sold here back in 89, via scuderia showroom in Vic. This is an old pic taken in 2004.
That is so cool that both you and your brother own Silver R32 GTR's!
Tiits and Ass, Titts and Ass
What are you up to Matty T ? A quiet SOB most of the time lately :P
Lurking mate, just lurking, i am a quiet SOB of late :P
Awaiting Container "A" to arrive, so i can have my goodies from our friends in Japan. That and i should see if my manifold has been started too, then i can get into swinging spanners and taking the TD06 kit off......but as im going to be moving soon, i would prefer to keep the car in a driveable state (well, drive on drive off the trailer anyways :laugh:)
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
