You can afford to raise the height of the car, easy fix for clearance
She drives really well thanks Bobby.
There's a li'l bit of scrubbing on the front tyres, so I'm thinking of lower profile or rolling the guards (which I've been told not to).
I think we might meet at some stage time/commitment permitting.
Again, thanks to all of you guys for support - the more warped it is, my humour appreciates it.
I run the 255/35 on the front. Mine are rolled.
Honestly Terry I'd have the front slightly rolled.
If it's the original paint and guard warmed before rolling there will be no paint flake.
(Resprayed guards and doing them cold will cause that crack and flake to happen)
Thanks for your input to Mick.
So it looks like...
1) tyre change to 35 profile
2) source progressive springs to suit Bilsteins > raise car
3) yet to be considered > guard rolling
Terry showing off again
Clicked over 50,000Kms today.
Even as a kid, I used to love things that glow in the dark.
One of the things I'd purchased before receiving the car, thinking, "What do I need a glovebox for anyway?"
Not sure if I'll be looking over to the left that much though...
  • Like 1
The rack Richard makes it (the R32) feel heavier than what it is. Or the corollary: the R34's rack makes it feel lighter than what it is.
Yes I like its 'rawness' a great deal. The R33 (which was my first GT-R) had a bit more oversteer which I actually liked.
I'm glad that I have upgraded the brakes, rotors, brake lines and castor rods on this R32.
Very well behaved. This is my 5th GT-R.
The 35 profile tyres have now eliminated scrubbing (compared to 40)
Thanks for asking :)
another N1 with A/c in it
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
