Yes Anthony. Not sure whether it should be fixed or left taped off. Security install today and they also do air cond. I think I'll ask them to test it.
fix it. May as well enjoy the little luxuries this R32 N1 has to offer
Plus it's summer :)
It's just my opinion. I think it distracts the eye in the cabin too much, although you can't miss it.
Personally I'd go oem or the black/ silver Nismo.
Sometimes understated adds much more and allows one to appreciate the entire view
Edited by Sinista32
The leather one is nice
I've got one of these which I took off and put OEM back on. Prolly see it in FS one day soon
http://www.thenismoshop.com/Nismo-Factory-JDM-Titanium-Shift-Knob-C2865-1EA02US_p_89.html
Thanks all of you fellahs - you too Brett.
Q. Did Nismo ever bring out a gear knob with the old fashioned Nismo logo in/on it? The same font as on the LMGT1S?
can't say I have ever seen one Terry.
Richard, I prefer a black knob over a white knob hey? Haha :)
I've also had the nismo knob like terrys and the long alloy nismo knob, I too reverted back to the oem knob...as a result, the 2 above mentioned knobs are now in my display cabinet.
The oem knob just feels right and doesn't look loud. Personal taste.
