The supra looks cool as! You need to show these to the organisers of that aussie mini cars series that supports the v8 supercars, mini supras and gtrs tearing up the track would look great, altho they might get banned again :)
I thought one looked bloody familiar Dave...
  • Replies 224
Posted Images
These mini cars look absolutely awesome, thanks again Age!!
I shrunk it and tried to use it as my avartar, but the stupid computer keeps uploading the current pic. I even deleted this existing avatar, then attepted to upload the new one, but this same pic appears :D. New avatar size is 120x96pixels @ 17kb, so i don't know why it is not working :)
Al, just give it a few days and It will reset.
Right now for me, your AV is the pic of your mini car, but the pic seems a bit stretched
A quick thanks to Joel for his Quality pics!
Don't suppose you got a side on of my car? ............silver 4door R33
Did anyone get video of me stacking the tiny motorbike? I will go you halvies on funniest home videos!
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
