  • Replies 45
Meguiars products. Bit more expensive, but worth it. I use their polish and wax, and some interior stuff, looking for the plastic cleaner to do headlights, but can't find it anywhere.
I use cheaper stuff for tyres and rims, I have found all of the rim cleaners I have tried are very similar in result.
Mostly use meguires but I find as far as a quick polish goes i usually use Eagle one - it requires less elbow grease as Meguires and I cant complain the way it brings the car up.
Why oh why did i buy black haha
Originally posted by Adrian_perth
i use amourall
this blue liquid crap
some sought of special
car soap crap
which polishes at the same time
and boy does it work a treat!
adrian :P
OK, I've been biting my tongue for a while now, but I've had enough. You seem quite oblivious of this fact, but a web browser will AUTO WORD WRAP POSTS! Yes, its amazing, isn't it? Ever wondered why everyone elses posts take up 12+ words a line while yours only take up 35 characters? Its because they aren't pressing enter when they run out of room in the text box. And no, a new line is no subsitute for commas, fullstops and other punctuation.
I always thought room temperature IQ was all that's needed to post on forums, but its time to rethink that one.
Anyone who thinks I'm being too harsh should consider that well constructed sentences is the only thing seperating us from the teens on fast fours forums or the gits on irc. Written communication is vital to get your point across and poor form reflects on the forum itself. To quote a favourite forum of mine, "All of us who spend any significant time on the Internet know that written communication apparently is at the bottom of most message board posters' priority lists. From horrendous spelling to unrecognizable grammar, people make idiots out of themselves every day... and most don't care."
Nice one Gradenko, I think you speak from all us here. Adrian, I like you, but stop hitting enter, cover it up if your that unco that you can't not hit it.
Back on Topic:
I use Brasso for my headlights, it works good, but does need reapplication every 2 weeks to stay looking good. I've heard Mothers is good, but have no idea where to buy it from.
See'ya:burnout:
Meguires on the outside....
go to www.mequires.com and hunt down their online car protection guide... it asks you a heap of questions about where you live, what your cars exposed to, and (essentially) how much you care about your car.... adn then puts together a program for you based on your answers.... (not all the products listed are easily available here unfortunately, but with a bit of hunting, you should be able to get them, or something very similar)
On the inside, i don;t use much except for the armourall 'new car' cleaner.... similar to normal armour all, only with a lemon scent...
and Paul, I'm pretty sure you can pick up Mothers at Marlows, same as Meguirs, it's just that their range is pretty limited.... Wonder if somewhere like the PPG distributor would have a decent range of car care products?
Maybe one of Perths "premier" speed shops should start carrying it... :-)
(BTW, Speedworks/WheelsWorld stock Swissol cleaning gear, which is apparently better than Meguirs/Mothers, but not cheap)
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
