  • Replies 67
PM sent Christian.
to all,
The CATs are now ready to go, and you dont have to wait until next Friday (GB close date) to pay and get your CATs. Just PM me anytime from now till close of GB with your address details and i will PM you my account details. The CATs will be sent out same day the payment clears.
cheers
Hi Micheal,
Are you in Sydney?
I bought the split dump off You, few months back. (Picked up from your bro)
If possible I will meet up with him again?
and pay cash to him?
Cheers,
PM sent!!!!
All PMs sent/replied to!
MintR33,
It depends on the amount of people that miss out and want a second GB organised. If there are enough people that ask for a second GB, i'll make one. The only way i can get these prices is by getting the cats in bulk. We'll see what the responses will be like by the end of this GB.
cheers
hi,
yes the small body 3" cats (pictured on the second post) are available in the group buy. let me know if you want to be put down for one, and for which car.
cheers
5" round body, 200csi metal inside - 706.2 CFM <<<=== that cat looks IDENTICAL to my 5inch body metal cat on the inside how ever i have 4inch in and out.. but i may be needing one for a r32 GTST bolt in.. 5inch round body one bolt in for r32 with flanges and temp sensor i will let you know today if i need it.. will speak to the guy todayseeing as its 440am
rb26s13,
yes it has the same insides as the metal cat (200ccsi cell), except the metal cat has a 4" body with the 4" substrate. thats why the catco metal cat flows higher (5" body, 5" substrate).
let me know definately and i'll add you to the list.
cheers
hi guys
just letting you know that the catco metal cats have all sold out from catco and there should be more coming soon from the USA shortly.
all the people in the list (list is up to number 15) have been catered for, as i have picked up the cats already but any new people who wish to be added for a catco metal cat, there will be a wait. i will find out how long this will be shortly and post it.
if anyone wishes to back out of the GB and has secured a catco metal cat, please advise me as it can be made open to someone else.
cheers
Hey BATMBL,
I bought one of your 3" large body cats a while back to put on my old R32 (which I've since sold) and was really happy with the product...now I'm trying to decide whether to go another for my R33 or go the whole hog and get a Catco metal cat.
So we know the 3" Catco metal cat flows 706CFM, but I'm interested to know the flow figures for the 3" big body ceramic substrate cat so I can compare & decide?
If you could let us know that would be great!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
