Called them up. They want to charge me $500 for installation and machining on flywheel. I was like "WTF!" , laters
$499 of that is simply due the pain involved in getting the top starter motor bolt back in.
If you've ever had to do it you'll under stand! :D
Well I have no idea how much a clutch install is worth, but Bens time is definately worth whatever price tag he puts on it. I guess you could go to any unknown mechanic that probably sells stolen parts and breaks/steals a bunch of other parts on your car while they're at it, so you keep giving them/losing money for months, but ultimately you pay for quality.
Of course some mechanics charge more than you'd expect and yet still do an extremely crappy job, but I've never heard one complaint about Racepace or their work, unlike most other 'performance' workshops in VIC.
Didnt you notice something there Snowy?
bcc23 is obviously paying to get it done.
So another obvious, he has never done it himself, just another internet mechanic ;)
Wonder if he can fix my browser, it wont stay the size i want it to :)
No ones forcing you.
Get it done wherever you want.
Im happy to pay the price for the best GTR workshop in Australia to work on my car. Considering the time & effort Ben has put into my car over the years & the care and attention to detail its received when there.......
Sounds like you have been going to the wrong mechanics, don't put everyone under the same banner :).
Not all good, honest, mechanics charge top dollar :cheers:
How many people here can honestly say they have only used the one same mechanic for the last 6yrs, and not just to do oil changes, i am talking serious modifications.
Not all good, honest, mechanics charge top dollar :ermm:
sometimes it takes some people longer than others to see whats really going on
Still waiting...
Unfortunately you had a major falling out with Vic, but I heard two different sides to the story. Before the parting you were very close to Vic and George, so if you have anything else to add I am more than willing to listen. As the falling out between both of you was personal, I decided to keep out of it and hopefully remain friends with both yourself and Vic.
To date I am yet to see/hear any justification why I should go elsewhere. His work has been A1 with reasonable prices, and my car has been proven to be a very neat and strong formula. Not saying he is perfect, as every one/shop has a few irritating moments, but at the end of the day the "whole picture" is completed to a very high standard.
If you have any information to the contrary I would really appreciate it if you told me directly, and in private.
Well said Rod.
Thread closed. Its quickly turning to shit.
I have my own views on many places around Victoria as i've used many and only found one to be worth the money.
cheers
Guest
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
