  • Replies 242
I get usually anywhere from 380-420k's to a tank, fill up around 3 times a fortnight, mostly freeway driving, but still quite good regardless for a 350rwhp car. 320ks has been my lowest ever tank because it involved 2 cruises & 3 days. :)
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2217977
The GTR tank is spose to be about 72L, but when I fill up I put $70 in which fills it up quite full. $70 = 46.6L, is my tank smaller or something???
I usually manage about 380k's, 90% of that is peak hour traffic. I got 430k's a few weeks ago, I was quite proud :nyaanyaa:
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2218512
Damn $70... I only spend on average $55 a week
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2218629
Oh how the hell do you guys manage so many km's out of a tank? I get about 250km out of a tank of BP 98 and I have to fill up twice a week. 50% of driving time is open road and the other half is in the city.... :nyaanyaa:
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2218697
i get around 450 a tank in my gtr ..
Tom yes a gtr tank is 72 litres but there is asort of air pocket in them the most u would ever be able to put in them is about 65 litres
i can only fit 63 litres in mine if the low fuel light is on
most weeks i use around 80 bux for fuel (over 10000 k's since i gotthe car in January)
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2218875
Hey Nastazia...is the tank empty though...ie when you fill up how many litres can you squeeze in? Reason I say that is the fuel senders in the 33 can be a bit dodgy sometimes and give a false reading. Should definitely be getting more than 250km in a fairly stock skyline.
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2219435
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
