quick track...satelite tracking?
no such thing as fast track.
theres quick track, carcom (dont think its around anymore though) and navtrak. then theres the different ones which are one of these three but renamed.
navtrak is the pick of the bunch as it has a much wider reception area than quicktrak.
hey alex,
yeah when i was talking to the prosperion guys they said that i'd have to get NavTrak installed. i think they said 1600 for installation and coverage for the first year, then 300 a year after that for coverage. I also think they said that NavTrak was better because it had like 3 satellites monitoring instead of 1 for quicktrak, something like that.
chinny
how's quiktrack's coverage in Victoria?
CarCom is a joint venture between NRMA & RACV's intellematics tracking system. Why aren't they around anymore? Went dodo? If so why I didn't hear anything about this before. It should be big news in the media.
i got a sms tracker installed, its got 3 immobilisers n the usual alarm but what happens, when the alarm goes off i get a sms message to my mobile, n if i dont reply the car calls me on my mobile, it lets me know what part of the car has been broken into, my mate installed it for me so i got it cheap but its usually round $1500, ive been told that for sum 1 to steal the car it would take them round 30-45mins and by that time i got a msg in round 1min, its a alternative to consider.
thats my 2 bob :(
ah yeah, i remember now. One of the systems uses like GSM, and another is Satellite, each had it's own advantages and disadvantages. Like if u parked in an under ground car park, stuff like that.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
