  • Replies 904
Posted Images
25 can still and is very often a rating point. It's just that they've introduced others. And not all companies are the same. I'm sure Shannons use both 25 and 29, for instance, while LSV aim for the lower risk segment.
  • 1 month later...
For grey imports?
Depending on your age, record, circumstances and your car's locality, value and storage conditions
Best options are still...
* Shannon's
* Lumleys Special Vehicles
* Just Car
...now that Guild Insurance and Famous are off the 'radar'
Just got a letter from justcar, im moving up to rating 1 and the new insurance is $98.09/month. That is with $1100 adjust excess.
My previous was $221/month, I'm assuming rating 2 (need to find the paperwork), and again with $1100 (I think) adjust excess, does that seem like a huge drop to anyone?
I'm not sure if I was overcharged before, or if its just combination of going to rating 1 (had this car insured for 1 year now), and some tickets/suspension dropping off or something?
I recently got a really good quote from lumleys, less than half what I'm paying atm. But I discovered in there pds illegal or non certified modifications will void insurance claims. Anyone know anything more about this?
Cheers,
Anthony
Cheers,
Anthony
Generally unless the parts cause the accident they must pay you out. I've never once heard of a claim of say having a BOV or a big turbo meaning say a rear end accident is not paid out.
If you put the wrong wheels on and they fall of causing an accident, then yes very likely they will void your claim.
What does the document specifically say? MAY void or WILL void? Does it have any examples? Ask them to clarify.
Yea I did ask that question but the guy seemed to think it wouldn't be covered. I may have to look at it again, from memory illegal modifications were under the 'what's not covered section'... May have to read closely again, but that stopped me from rushing out and getting it, was upsetting as I thought I was about to save 1k!
Sounds more like they have specific clauses to stop modified cars being insured as they are high risk.
Go with a company that can explain their policies properly and give you a guarantee your car will pass.
Yea That was my thinking.
I may push the question further a see how I go.
Just ask for a copy of the policy booklet. It beats a verbal over the phone.
Yea I just searched the pds then, says anything the state it's registered in deems an illegal modification will void the claim unfortunately.
booki - you need to clarify which type of cars!
if its a standard i30 that you dont care about, any of the online insurers.
skyline?
all been posted in here, the best thing is to call eazch company, get a quote, read each PDS and choose wisely.
OR
pay a bit extra, go through an insurance broker who will find you the right cover and do all the hard work for you.
ant123 - of course they'd say that on the phone, most people will read it straight from the PDS
some people on the phones wont even give you a "hypothetical" of a situation.
their answer is the PDS with policy conditions, exclusions and limitations.
Just car cover any illegal modification provided it doesn't contribute to the accident. Go with them, wind the premium down and excess up providing you aren't a moron driver and everyone wins.
Yea thats who i went with 4 months ago.. might need to go back and revisit my preimums... they are so high though in comparison to other companies... with all the extra added premiums... i will be paying 2-4k excess (or knocking the agreed value down by that much which is already low imo).....
might see if i can do something with shannons, they were willing to offer an agreed value 8k better than just car.
Cheers,
Anthony
Even at shannons you pay more than just car and I am 25 with no claims or at fault accidents in 7 years of driving sports cars, and that was knowing someone who worked there as well. if you are likely to claim often shannons will work out cheaper but I don't plan on driving my car into a tree every few years hence so far just car has been better value.
Edited by Rolls
Ha, im in the same boat.. same age, same history.. i to plan not to crash my car!
I may revisit my excess with Just Car then...
ps just read shannons PDS, it states they will not cover illegal modifications, but it does not say it will void a cliam, but as you said, they are more expensive than Just car, even on 'limited use' terms.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
