  • Replies 904
Posted Images
Actually AAMI lets you get a quote from a repairer of your choice, they will compair the costs of other repair shops and pick the best deal.
And there is a 3 year warrenty on all repairs :D
The reason that they have their own list of repairers is because they have already found the cheapest. Any shops that you find are unlikely to beat them, so they can easily make that offer.
This is a legitimate question - Say you get rear-ended, and go to the cheapest repairer you can find. How much extra would they charge you to respray the whole car after the repair, rather than just the rear quarter, which would look absolutely retarded when the front half is 5-10 years old?
Just called Famous for a quote on 3rd party fire + thieft and apparently they don't do it!
Full comp only, i thought that was a bit odd?!?!
Does anyone have any suggestions for thrid party insurance?
yeah im currently shopping around for insurance .... given both Famous n Just Cars a call ..... i'll be going with Just Cars. Famous is way outta the water with prices.
Open up your HPI mag and look at Insurance Advisernet, they are a client of mine and are very good brokers...they actually found insurance that I could include my girlfriend on.
Give Adam Lewis a call and tell him Neill sent you.
Cheers
Neill
  • 1 month later...
I just joined SunCorp Metway, Rating 1, 26 yrs old, modified r33 gts-25t as per below's signature. The premium was roughly under $1200, $1650 excess, no under 25 drivers.
A rating 2 with all the above was roughly $1450/year.
3rd party was $170/year, $1000 excess....
Pay by the month available at 15% more....
I have tried RACQ, they dun insure skyline r33's.
Give Suncorp a try everyone!
i assume this 10% discount for sau members applies to all types of insurance, not just full comp. ....?
r32 gtst, at 18 years, no previous insurance, 3rd party $400 approx. + $200 approx fire and theft. excess $1200 from Just Cars
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
