Hi people,
Tony hasn't put the second page of the entry form up. It's the part that needs signing so it's the important bit.
We've told him and it should be up later today/tonight.
Regards
Andrew
Ok, as we are operating under AASA at Winton, we don't need the usual signy signy bit for the entry form. So the documents on the WRX Forms are correct.
Let the entries flow....
Regards
Andrew
  • Replies 128
You going to throw the brakes on Dane? Im interested to hear your thoughts
I'm not sure yet Troy, if I get a chance to get them on I will, so here's hoping.
I'm not 100% that I'll even make it. The second hand box I just put in my car has a chipped tooth... FARK
It drives alright but the synchro from 3rd to 4th is gone, so I'm a little worried about smashing it at winton... Are you bringing the Tow truck Jack?? :)
It drives alright but the synchro from 3rd to 4th is gone, so I'm a little worried about smashing it at winton... Are you bringing the Tow truck Jack?? >_<
Sure am Dane, plenty of room for you!!!!
ahhhh you're are an absolute lifesaver Jack!!! :D
Now hopefully I don't need you to save me... :(
I'll send in my entry tomorrow.
How are the Alcon's??
Alcon's are doing fine, the rears should be ready in 3 weeks...
So what's this upgraded brakes you have?? :huh:
So what's this upgraded brakes you have?? :(
ahhh nice, nice, can't wait to see those bad boys!
I've borrowed Troy's spacing kit for the front calipers so that I can accept a 324mm rotor with the stock calipers. Just going to see whther it is what I'm looking for, and if it is would be a fantastically cost effective solution, so here's hoping.
Matt: sweet. I'll see how these go and have a chat to you about them :P
I've got a few things to check over the weekend. If everything is fine ill be putting my entry in on Monday.
I think i'll need some new tyres. I don't really want to use my semis, but if i do use them will i need a harness since ill be in modified?
muhaha Nick's entering the fray! w00t. nice one.. good to see another modified 4wd in the mix ;D
Tom, only "heavily modified" skylines aparently require a harness.. why dont you want to use semi's?
This will be my first trip to winton in the 34! can't wait.
It's good for drifting at Winton :D
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
