Howbout this one? Im hoping it says "changed at..."
The car is on its way from Japan, with 74,000km
that 1 appears to have been changed already...the 68,000 part is the kms it was changed at, and the numbers above are the date
[The jap numbers actually mean 8th year of the 4 emperors reign for eg. weird shit
quote name=Beer Baron' date='22 Jun 2006, 03:44 PM' post='2277076]
yes it says timing belt repalced at 64,286 done on the 20/9/2004.
Edited by BezerkR32
http://en.wikipedia.org/wiki/Heisei
It's not that weird, just different. The non-Christian Japanese may well think measuring your calendar in relation to the birth of Jesus is weird too :)
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
