Ronin 09 mentions above that he just replaced the rubber hose part of it with a braided maltech item. I would prefer that and am keen to know if they are available etc.
Seriously dude just go get a custom one, it wont cost much and you know its going to fit.
I don't think the problem would be heat transfer, but rather heat buildup in a shorter hose. It's definitely not a problem in street use. At worse in track use you lose clutch pressure and you go work out how to shield it later. It's not like brakes which could send you into the sidewall.
Below is how the standard maltech one is (unless they make a custom). This is how it is hooked up on my car, and I assume everybody else.. staight from clutch cylinder to slave cylinder. It works 100% fine. Why wouldn't you want to piss the extra piping off? You'd take away half the benefit of the shorter line I would have thought? The longer a fluid line the longer it takes to build up pressure, and hence a doughier pedal.
Juts like brake lines, removing the steel pipework makes no difference as it doesn't expand under pressure. Only replacing the rubber hose makes a difference.
:P cheers :D
Yep.
Hydraulics isn't effected (for the most part) by the volume of oil in the system.
The oil doesn't compress like air does.
You could lengthen the hose by a few meters and not feel any difference.
The rubber section is the bit that makes the difference.
:P
nismo braided clutch lines are in stock in japan can get them through my friend for about $80-$85 delivered (just depends on the days exchange rate). if you need one benm i'll grab one for you next time i'm getting some bits.
This is true, however, isn't it the pressure in the clutch cylinder, built by the pedal action, which is pressing the fluid down the tube? And pushing a larger amount of fluid down a longer tube would require more pressure than pushing a smaller amount of fluid down a shorter tube? Just like a more powerful pump is required to pump fluid over a larger distance, compared to a shorter one?
Maybe the difference is negligible in this situation, but that is the way I would have thought it worked?? I'm just thinking blowing into a short straw, as opposed to blowing into a long one, and the effort required for bubbles (air pressure) to appear at the end. Somebody point me to some fluid dynamics site >_< I'm not saying I'm right, I just want to know why not..
  • 13 years later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
