So yours takes a little longer to shift sometimes? I've noticed mine tends to be a bit laggy on the kickdown and if i put my foot to the floor, it feels as if its slipping pretty badly and doesn't really take off that well. I've acheived the best acceleration by easing the throttle in. Slamming it to the floor on takeoff just seemed to overload it and it made a lot of noise but wasn't that quick. Felt like something was slipping - not sure if its the clutch packs not engaging properly or the trans slipping a little. On another note, i have a guage on my dash saying "front torque" measured in N-m x 10. It only seems to make it to about 3 on the guage - meaning only 30 N-m. I'm sure the needle should go higher. I'm talking about when its in "synchro mode" - which I thought was 50-50 split (although I haven't seen the needle move at all when not in this mode - even on hard launches). Hoping my guage is wrong. Everything else seems to work however. And it does feel quick when I give it a bit of stick. :D
I cracked how to launch it...Make sure synchro is off!....put it into 1st then you just gotta get the boost up.....left foot hard on the brake and right foot to the floor on the loud peddle.....rear wheels should just start to spin as the boost comes up....then let off your brake and see you later.....shift at between 5500 and 5750 and it should bounce of the the limiter then come back to a solid no slipping second....ect.
only other less violent way is as above......get it moving on half throttle first then foot to the floor.
P.S. You should be able to do better than an X5......I've smoked a 2002 WRX and a VZSS(Auto)....just!
yeah that torque gauge will work in the wet. trust me :P
although i dont have one (RX and ARX lacks the 3 gauges) i can feel the front grabbing as the rear loses traction.
and yeah kick-downs are horrible. flooring it to kick back takes longer than half-throttle to kick back i rekon. because of this ive had to adjust my 'pull out' technique when i see a lane empty lol
yeah that torque gauge will work in the wet. trust me :D
thanks guys, this info has helped heaps. I had a shift kit in my last stagea (s2) since I wasn't happy with how long it took to shift, particularly using tiptronic. So I wasn't sure what was "normal" for the M35.
I've yet to try it out in the wet - I know with the last stagea even with 160awkw I could stomp my foot down in the wet in a straight line and it would just grip and take off. Wouldn't try it on a corner though - thats asking for trouble no matter what car you drive :P
The guage thing still has me puzzled. It definitely feels a little different in synchro mode - particularly during tight cornering at low speeds, but the guage just didn't show as much front torque as what I expected.
Anyways, better move this discussion into a new thread if we wanna continue with it... :P
So yours takes a little longer to shift sometimes? I've noticed mine tends to be a bit laggy on the kickdown and if i put my foot to the floor, it feels as if its slipping pretty badly and doesn't really take off that well. I've acheived the best acceleration by easing the throttle in. Slamming it to the floor on takeoff just seemed to overload it and it made a lot of noise but wasn't that quick. Felt like something was slipping - not sure if its the clutch packs not engaging properly or the trans slipping a little. On another note, i have a guage on my dash saying "front torque" measured in N-m x 10. It only seems to make it to about 3 on the guage - meaning only 30 N-m. I'm sure the needle should go higher. I'm talking about when its in "synchro mode" - which I thought was 50-50 split (although I haven't seen the needle move at all when not in this mode - even on hard launches). Hoping my guage is wrong. Everything else seems to work however. And it does feel quick when I give it a bit of stick. :P
Try getting a full trans service at a "reputable" Nissan dealership & request that the "New Car Satchel" be put in.
You will know if they have used it as you will get quicker shifts.
They are not supposed to use it on cars that are out of warranty. Good luck!
Synchro is not a 50-50 split. When I use synchro (not often), it immediately shows ~30-40Nm on the gauge... whether I am cruising or standing still.
Try accelerating from standstill with your front tires on tarmac & the rears on gravel, that will instantly let you know if your gauge is working correctly.
heres a sneak peak of the new engine setup in my stagea, the turbo side of things isnt on yet i gotta sort that out next, should be up and running within a couple of weeks.
gone 30det yet? :) i want to :P
what set up did you go with?
Edited by Ryan1600
yer its a rb26/30 with single gt3076r turbo, pretty simple setup but should go alright, its only 2wd for this setup at the moment, i wanna see how i like the 30 compared to 26 first before spending money on the 4wd adaptor etc.
Edited by unique1
and can be made too look standard-ish :D you NEED a build thread!
lol, its not that special, nothing like it was anyway, its a stock rb30 bottom end (cost me a carton of jack daniels $90) and its been rebuilt back in 98 so its probably not the best, we pulled it down and bearings are good, the rings i dont know to be honest, ill wait and find out as we just left the same ones. I bought the 26 head on a low comp complete rb26 a while ago and got that recond, all up its a pretty cheap setup, the biggest cost is the head, turbo, wastegate (got one here lying around) and ecu (using my current autronic), im using stock gtr injectors, coils, cams, etc, the setup will only make 400hp at wheels max because of the turbo size, but should make boost very early and plenty of torque. It will never compare to the other engine with 560hp+ but its gonna be the daily driver asap so its gonna have to do.
hows it go for bonnet clearance brad?
the rocker cover breathers look to be pretty high up.
i havent tried the bonnet yet properly, but those breathers are just sitting on the top of covers, they havent been pushed in covers yet, so they will drop 20-30mm when put in. I have to remove the strut brace because the turbo is sitting in such a shit position, but i cant be bothered changing the manifold yet i just want it going, ill eventually redo the mani so it sits alot lower and tighter to the engine.
I doubt you'll have bonnet clearance issues, Brad. I had a look under the bonnet of mine today, and the soundproofing material has cut-outs where the standard cross-over pipe/throttle body, strut brace and rear breather pipes are. Also, the strut brace itself looks like it is actually higher than the section along the firewall where it seals against the back of the bonnet (just in front of the windscreen).
Heres a pic of mine from the Adelaide Stag cruise a couple of weeks ago. Its amazing how every stagea is different somehow. I really need to fill those gaurds with something.
Edited by cahlie
Right, I actually got a decent camera this time, so I took some better pics
Inside:
and a couple from a meet on Saturday:
Edited by mr_infamy
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
