lol i know haha ... used this product to get them off ... then arm got tired ...
got some cutters i've had for about 2weeks now i was sposed to use on it ... maybe next time i give it a full on wash i may think about it ! :yes:
thanks for reminding me buddy
how do i upload pics like the ones here ?
when i do it you have to click on the thumbnail to open .. might make it easie to view
Just type blockquote><p>First, you have to host the pictures on an external website (I use <!--url{0}-->, as there
Hmm, I wonder if that is Ryan aka BOZ22N?
this is my new stageas heart, it fired up for the first time saturday and runs like a dream, nice and quiet for a change, its untuned and few minor issues with ecu settings but shouldnt be far off being sorted. Ill post of a pic of the outside of car soon as im doin a few body changes and painting my rims etc soon.
that turbo looks like one of my TD03's with that filter. :wub:
painting the rims black? you know how good black on silver is. :laugh:
the turbo is stock mitchy, just high mounted it :( Im gonna paint rims soon, but gotta go do the hpi photoshoot first before i paint em. I finally got it running on stock coils and ignitor yesterday, runs pretty good, gonna book a tune asap now and then organise the engineer. I got to hand in my plates now so its currently unregoed lol.
Oh and another bonus is i fitted the bonnet on and it closes with about 10mm clearance everywhere so stageas and rb30's are meant to be :)
Edited by unique1
at least it will be responsive with the 'stock' turbo. :sick:
that's plenty of clearance, but then it does have a lot bigger bay than the 32..
i heard a rumour you were selling it and buying a legnum though? something about being a better car??? :)
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
