here's a couple of my stag at Pt Broughton new years day 2009. She towed the 1800kg van with ease 15.8L / 100km and 17.8/100 on the way home with a huge head wind.
Bloody Hell Dan! I hope you didn't encounter any speed bumps along the way.
That 1800kg's definitely puts a strain on your rear suspension.
Nice towball setup though :D
Who did the fabrication and install?
Nice towball setup though :blush:
I built the bar from a modified magna wagon setup, Was a pretty big job to get adequite fixings on the M35 chassis rails, wheel well & back panel. The entire setup has about 20 grade 8.8 bolts attaching it. This setup is not rated as such but from my background of electrical and structural engineering i know that the bar is not the weakest link. I am more woried anout the ally sub frame, where other have seen cracking.
The car needs some air bags for towing the van as it sits pretty low and hopefully I can get these installed before my next trip.
Overall it is a good tow car, Very happy with my stag :blink:
side skirts only sitting on hence the gap at the front, just a quick test fit of the rims from my other car and now i think they are staying for good :P 18x10+20 offsets with 235 tyres, they sit real nice actually, the rear needs to be lowered abit more before i post a pic of that.
Edited by unique1
Man that looks awesome.
Do you reckon you will get any rear rubbing with rims that wide? I am about to fit rims on my car and I would love to fit a set of fat alloys like that.
side skirts only sitting on hence the gap at the front, just a quick test fit of the rims from my other car and now i think they are staying for good :D 18x10+20 offsets with 235 tyres, they sit real nice actually, the rear needs to be lowered abit more before i post a pic of that.
the rear offset is pretty aggressive compared to fronts, i think it shall tuck the tyre in the gaurd but the rim will stick out, hence the reason for 235 tyres so they stretch abit, this is a pic of the rear but its not low at all so when lower it will tuck in abit more. I have the car on the brick trying to get it to lower down abit but it didnt do much. the front rim on in the pic is just a 33 gtr rim.
I wont be driving the car with these on for a while yet so cant comment on scrubing etc until i test them.
Edited by unique1
^^^ you'll be right when you drop it a little, you'll gain some camber and she'll be apples - beware of inner clearance though as you'll be mighty close to the shock
here's my rears that sit the same as yours, just rear end slammed
good to see another stag with mint wheel fitment
hey mate nice to see another good lookin yellow stag, I'm gettin some 18x8's on next week with an offset of +20 so ill chuck up some pics when they are on,
any chance of a side on pic of your car so i can see the mags better? what brand are they by the way?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
