Ok. I sold my car last week it's in QLD somewhere catching some rays.
It's been replaced with...
[edit: you have to go through the next pages to see build up pics :)]
EDIT:::::::::::::::::::::::::::::>>
Project MAYHEM has begun. See more pics page 2 onwards.
<<::::::::::::::::::EDIT
  • Replies 80
Posted Images
Basically I had to pay off a whole bunch of debts. I kept some money to buy another car and the r31 is it :(:D
I've already done some cutting of the front bar for the fmic and put on some tints (Thanks Greg from Unique/group buy thread) :(
Just bought some s13 lower control arms and brakes today in preparation for the s13 coilovers. (Thanks to Kirk/Initial Imports, who can get you rb74 pads for $136 an end) Hopefully I can find some decent/affordable second hand ones. I've also ordered a intercooler kit for it today from gktech $349+45 delivery and they have kits for a31s!!
Need the diff fixed.. anyone know how to weld? I smell bacon :(
you bought a 4 door just so you could stay in this section didn't cha? didn't cha?
if you were in melb I'd ask you to bring the car around to give it a spray in the paint booth to cover up that nasty paint fade.
You have a booth? I was going to hit it with some matte black but I'm not sure how long the paint will last (at $3.50 a can). If you can paint it for me it might warrant a drive to Melbourne and some sanding.... How much would paint cost?
and yes I did wanna stay in this section so I can find rims in 4 stud with GOOD offset and cheap (i.e. it'll hurt the guards) then I'm there :D well.. me and everyone else. Or maybe 4-5stud bolt on spacers.
Dude why did you have to sell it to someone in qld. Down goes the price of mine again, market getting flooded :)
Good that you sold it tho, must be a good feeling to be debt free again.
Dude why did you have to sell it to someone in qld. Down goes the price of mine again, market getting flooded ;)
not to hijack but OMG im going to be debt free this month !! :thumbsup: :PBJ:
Haha, I should be within the next month or so too. Quiting a job and getting a massive holiday payout also helps tho ;)
real men drive r31s. this is something that you SAUers will one day learn. awesome choice mate, you wont be dissapointed! should have got a silo though, is it gx (manual) or executive (auto)?
fmic orly, what motors goin in?
Debt free owns.. Actually I'm still in debt for a year or so but atleast now I can get my own place.. been shacked up at the gfs and nearly been stabbed a few times - not correlated really :(
I will have a cefiro one day again however, assuming I don't change my mind between now and the time I'll be able to afford one again ;)
As for the r31, s13 coilovers, VLT setup+FMIC. Hopefully drift pig. I was considering a 25/30 stock setup but with rb25 heads + ancillaries likely to cost over $1k it's hard to justify that on what is essentially a rolling fridge.
The thing is an ugly piece of shit with smelly interior (which will be removed) and piece of shit lethargic SOHC anchor as an engine.... Still - it is RWD, a Nissaaan and can be drifted... and funnily has a RB sound and feel to it (altho a lot more asthmatic than the DETs). Spose that's not -too- bad. Morgs also threw in his trolley jack to sweeten the deal :D:D
Haha, I should be within the next month or so too. Quiting a job and getting a massive holiday payout also helps tho :D
lol I did the same thing! Except im using my last pay to pay off my loan and buying an LSD with my holiday pay out :(:D
well, sad to say but can't do it any more because the paint booth was just pulled down for a bigger one... so it'll be out of action for a month, in whcihc time i'll be in syd.
well, i'm in syd now, so gimme a can of aerosol and i'll help ya paint it ;)
well, i'm in syd now, so gimme a can of aerosol and i'll help ya paint it :P
Hmm I bought 8 cans of black at $3/can so it might happen :D
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
