Well guys/gals - its finally here! My turbo back exhaust is complete! BATMBL s/steel front/dump pipe, large 3 inch catco cat and Trust PE2 cat back! About $1400 odd, for the whole lot including installation and it sounds great! (well to me anyway) Got RE Customs in Springvale (Vic) to install it - and yeah, it makes a whole lot of difference. Havent really taken the car for a good spin yet, due to the rain, but it feels a lot better to drive. Its extremely quiet too, until about 4000 revs - then it makes a howling sorta sound.
The overall installation was pretty much spot on - everything fitted perfectly according to Ray Evans. Took it in today at around 11am, was finished by about 3 (including my 5000klm service).
Will post up pics after I washed the car.
(Michael - batmbl - thanks heaps bud, was a great buy the dump/front pip and cat :P )
Edited by emsta2003
https://www.sau.com.au/forums/topic/125272-new-exhaust-updated-with-pics/
  • 3 weeks later...
Lovely exhaust... got one on my 34 :woot: You want it to sound even better? Get them to cut out the centre muffler (resonator) from the PE2 and replace it with 3" straight pipe... done that to a few cars now (all with PE2s) and they absolutely roar after!
Thanks bud - I am quite happy with the way it sounds, as it doesnt attract the cops - how much louder would it be without the resonator?
There are reasons for doing it though; not all for the sound...
1) The resonator (in my case) was hitting the uni-joint (???) after the split front/dump installation so it had to be removed to stop the contact.
2) The resonator on the PE2 is not straight; if you look at the entry and exit; it's actually off-centre. This can restrict flow... replacing it with a straight pipe will solve this.
stan, any resonators you cut off trust PE2s I would be more than happy to take off your hands. :woot: this goes for anyone else in sydney too.
how many have you got there? lol
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
