  • Replies 70
I use to be a Honda car fan when Senna was winning.
After Honda pulled out I discovered the GTR and Bathurst. Haven't looked back since.
Integra Type R and NSX are the only ones worth mentioning. Rest are like sleeping pills.
pffttt... i get looks everyday in my skyline even if they are fairly common around now..
and honda's ... nobody looks at a honda :D
Weren't they using Turbos back that era then too? ;)
Originally posted by dw
but a whole new scene has come over to them, a scene i don't want to be associated with. i am of course talking about the HONDA scene..  damn skylines used to be a very respectable car!!!
are you serious?
I've seen the same kind of owners your referring to drive porches, and ferrari's. you think if I could afford one I would not buy a ferrari because an owner wore his cap backwards?
:chairshot
did you honestly think we would agree with you??:chairshot
Yeah there are plenty of wanker skyline owners out there these days. About 2 years ago I used to wave and get waves back etc etc but these days people look at you weird if you do that.
The skyline community has gone to shit to how it used to be a few years ago.
I have a skylines and luv 'em but I don't wear my caps backward, and my shirt collar are always folded neatly.
What a lame generalisation you have there... where's this stupid idea comes from anyway?
I like piano accordians and own a rubber chicken that I take with me in the skyline.....wow he's right the skyline community has gone down hill!
But dw,
Don't leave us here in steady decline. You can see what is happening. You are a visionary and possibly the only hope we have of returning to the 'cool' state of your favour.
I have a singlet but its only a bonds one, maybe you can reccomend a label to buy that will make me appear more cool like you. Do you suggest Wutang clan?
What about music?
I like to play russian polkas and swiss yodeling at full volume with my arm out the window when I pull up at the lights.. do you think I should go for polish folk music instead?
please help us all before its too late.
You are joking, Suzuki Gti's are for girls. In fact, I am a girl and I wouldn't drive one. Sorry but nothin cuts it like a Skyline. If I had enough money, my Corolla would already be on fire.
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
