I turned up with some mates....
and you guys left...
too much goin on out last night..
yeh we saw u guys, we were jst goin 2 the servo to get some drinks, wen we came back u guys had left, and someone told us to go to brand depot for the ignition filming, so we all ended up goin out there..
there was a lot goin on last nite though..
I got there about 10 and as i was about to leave when black 32 turned up so we had a quick chat then followed him into civic.....sorry mate i forget your name :) . The 300 was there too.
I saw you and waved but you just kept driving into civic when I was going back to the museum with MKD-R33
Saw a few of you when you all got to Brand Depot.
2 white 33s
1 red 34
1 blue 34
1 gold 33
1 gunmetal 32
Can't remember any others.
Oh, thanks to the dude in the white 34 for confirming that I can get the rims I want in the size I want!! Top bloke (don't remember your name sorry!)
Hey MIVEC I didnt see you at Brand Depot... you should of came past and say Hello :)
QUOTE(R34-GTT @ 14 Oct 2006, 06:21 AM)
Not many turned up besides MKD-R33, Viper32 and a 300zx
haha,
there was a good reason why we left too.
definately worth it but
Hey Mladz....reckon you could tow my car home for me :laugh:
I was the one telling you to get your car lowered as you left.
LOL thought it was you cause I seen you with SLITHER once hahaha and yes I will lower my car hopefuly sometime this week or whenever cause I do agree with you :laugh: its a 4wd height :rolleyes:
I stayed around at the brand depot after most of you left. The cop’s ended up leaving us alone and they only defected one black Ute. The cops came around and said we were fine as long as no one did anything stupid. Nick showed up towards the end in his 32 beast (on the cover of HPI magazine No.67. I said hi but he was pretty busy with phone calls and the ignition DVD guy’s. But it wasn’t long after nick arrived that the airport security said they didn’t want us there anymore and we had to leave. But it was a good night. Met some people I didn’t know and saw some sweet ride. What more could you want (well a lot actually, but lets not go there)
yea might com check it out everytime i go there tho it's empty cept last week with the white 33 gtst sossy i for got ur name too..
LOL that was me!
I wouldn't mind coming out tonight but ill be with my girl and my car will be wrapped in cotten for tomorrow
:laugh:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
