As mentioned, there are no other Skylines that turn up from Canberra Cruises except for mine. They're probably just randoms... In case people haven't noticed there's plenty of them out there that aren't necessarily associated with any car clubs or forums.
I'd just like to add to back up my previous post. Canberra Cruises are a pretty mixed bag in terms of people, ages and cars. They're also pretty friendly and it annoys the shit out of me when there's always the need to point fingers.
I saw a Skyline do a burnout today they must be from SAU!!
Y?
thats why we moved the meeting place (note the name of the thread "Friday Night Not At Museum") because d1ckheads would show up and try to show everyone how 'awesome' they were by doing burnouts. all they did was prove to people how much of a tosser they are.
As if dude, burnouts are sik, especially in cold weather.
Does anyone wanna go for a drag?
Turbz etc... You wanted a race I offered sutton road racetrack , you never turned up
If we offer you a drag down the Sydney Drags you won't turn up
As for burn outs, go buy a falcon or commo. Skylines are performance vehicles of style.
Your comments are either from a child trying to get attention or an under cover cop trying to get members into trouble - neither are wanted here.
agreed...
No need to be like that fellas.
Sutton and Sydney are much to far for me.... I'd rather whoop your ass in a drag somewhere close in canberra.
After I beat your ass senseless in a drag, I wanna do some burnouts! I'll chuck my stockies back on, and I'll be spinning in 5th gear for ya!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
