http://www.ps3land.com/article-338.php
click this link an they have reviews of games, info on the ps3 pics etc..
Release date for aus is 17th november.
here is a vid of some of the games to come. I cant wait
http://www.ps3land.com/article-382.php
Edited by HR32_GTS-T
https://www.sau.com.au/forums/topic/126189-whos-buying-a-ps3/
  • Replies 459
yeah.. $1000.. steep price I think.
$999AUD for 60gb hard drive
or
$829AUD for 20gb hard drive
Not something you'd just lash out and buy spur of the moment, but more like 6 months of saving for it. People won't be flocking to it for a while I have a feeling. The price will be well above any of the other "next gen" consoles, and any obvious benefit?
The 360 can display some pretty powerful games as well.
Ill be definately getting one of these when FF13 comes out no sooner no later :)
Heres another good site for info and pics for u guys:
http://www.the-magicbox.com/
This is a top site for D/Ling small or large clips of games:
http://www.gametrailers.com/
Some direct links to pics of PS3 games:
Vitua Fighter 5
Virtua Tennis 3
Fatal Inertia
Need 4 Speed Carbon
Final Fantasy XIII
Metal Gear Solid 4
Ill be definately getting one of these when FF13 comes out no sooner no later :wave:
Vitua Fighter 5
Virtua Tennis 3
Fatal Inertia
Need 4 Speed Carbon
Final Fantasy XIII
Metal Gear Solid 4
wahoooo, another FF fan i thought i was the only one on here, final fantasy rules best games eva made, cant wait to buy it.
Like someone already said they gonna be over the 1k mark.
I think there really going to struggle because MS will no doubt drop the price of the 360 when Sony launches PS3. Its a big call for someone who doesnt currently have a console to buy a PS3 over the 360 given there will be a huge price difference.
As far as performance goes your not going to get any noticable difference, Sony will be crossing there fingers and hoping the die hard playstation fans will pull them through this one.
I dont want to get into a tech spec argument with anyone, but if you stand back and look at the two systems and what they can do, the compatibility and versatililty of the MS system is in my opinion is going to dominate over the next few years.
This is just my opinion, and opinions are like assholes as they say :-)
Cheers Stink
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
