i just added a hiflow turbo to my skyline
it has these mods
apexi
3inch dump pipe and exhaust
Z32 airflow meter and pod
gtr fuel pump
front mount cooler
blitz boost controller
high flow ball bearing 450hp turbo from turbo australia
standard manifolds
on 10psi it made 251rwhp but ran into nock problems
at 13deg timing could not run any more boost or timing into it ...
The nock would go to high .
they even richened the fuel up at the top end .... to stop it knocking but this did not help
It would not knock till right on 6200rpm ....
Any one else seen this problem before ?
dnyo sheets are here http://www.tuffstreetcars.com/skyline2.pdf
http://www.tuffstreetcars.com/skyline.pdf
https://www.sau.com.au/forums/topic/126291-hi-flow-turbo-problem/
He will be running a SAFC which you can run aftermarket AFM's with. . The SAFC has limitations you need to compromize between your air/fuel ratio and timing this is fine with the stock turbo but it starts to get difficult when an aftermarket turbo is added to the mix. Its probably time to invest in a Power FC or similar you will probably also need to upgrade the injectors.
cheers
cheers
sorry i have a power fc just tuned on the dyno ....im not using all of the injectors i have yet as i cant up the boost or timing as the knock goes to high looking at the turbo housing size ....right now but im not sure thats why i asked
Looking @ the dyno sheet, the tuning is nothing short of below average.
Has the tuner got expirience with PowerFC's ... and turbo performance in general ?
Whats the fuel pressure like?
Personally i would say the problem begins and ends with the workshop you have there.
I would go somewhere else for a secondary opinion.
Might cost some $$ but i would think it will save you some hassle
Seconded
How can you have a power fc and a stock ecu? Piggybacked due to auto?
If it is a power fc tune then that is sub par, I agree with nismod, safc then acceptable and also explains your detonation issue and having to mess with the base timing rather than the specific cells where the detonation occurs.
yeah that's a pretty rough power curve. can see his mods to the AFRs were decent but the power is still quite ordinary.
Time to go for a full ECU, rather than a piggyback. If that is a full ECU then get a better tuner.
it has these mods
standard manifolds
A little off thread Dan, but do you know the ID tag numbers off your hi-flow core?
The guys from Turbo Australia are pretty good, just interested to see what specs they ran for your unit.
I'd have a few concerns about the output, given I achieved 223rwhp with a stock turbo @ 7.5psi and other similar supporting mods to yours. Look at the tuning I suspect.
cheers
Edited by Dale FZ1
cheers
hi i dont have the turbo now its back at there shop ...till they sort it out, stock one is back on and feels a lot better then the high flow right now ...so im not sure what the problem is
yeah sorry was late when i posted it just has the power fc handcontroler
Have you taken it somewhere else for tuning?
these are the guys the turbo shop wants to do the tune on it ...
when i bought the turbo i was told they done a lot of the 450hp hiflows , only to find out im now the first one they have done so they are trying to fix the problem best they can .
Edited by Turbo Dan
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
