hey guys just wondering what ever happened to GTR 700. Exvitermini.com hadnt been updated for a year and now its off. wonder if the car is gonna run again???
thoughts / on subject guys . :D
Its sitting at CRD, though hardly recognisable as its completely stripped :D
https://www.sau.com.au/forums/topic/126614-gtr-700/#findComment-2337639
so mario sold it to CRD and he isnt involved any more ?
Wonder why its stripped ?
Its stripped because its undergoing an extreme weight reduction...this is needed to compete on the world stage against the big Japanese and New Zealand cars. No point building a monster engine and driveline if your hauling all that bulk down the strip.
https://www.sau.com.au/forums/topic/126614-gtr-700/#findComment-2341158
Any idea why weight reduction wasn't carried out before? I'm sure it was done to some extent...
https://www.sau.com.au/forums/topic/126614-gtr-700/#findComment-2341450
Yeah...but you must remember...this car evolved from a HKS 2540 powered street car, and with the evolution of the car the goals of the car changed. This time the car is stripped bare and all facets of the car will be looked at with one goal....to beat HKS....CRD now have total control of the decisions, the build and the budget. They certainly have the expertise and personnel at their disposal to achieve this, but only time will tell.
https://www.sau.com.au/forums/topic/126614-gtr-700/#findComment-2341521
Niiiiice good to hear. I expect this will probably be quite unrecognizeable in its next stage - HKS's time WILL go down soon. No shame to them though, they were miles ahead of the game for years.
https://www.sau.com.au/forums/topic/126614-gtr-700/#findComment-2341539
i second col-gtsx
There simply sitting back and waiting :dry: they have unlimited budgets and data ..at the end of the day they have even created Formula 1 motors they arnt just a workshop there a a massive engineering race firm
https://www.sau.com.au/forums/topic/126614-gtr-700/#findComment-2341611
Once they beat the best ET of HKS i reckon you might see HKS come back to australia with a fatser time again or maby even a show down.
Whats to say Australia will be where they will have to defend their time? :dry: Heat Treatments may only be a meet away from beating them...
https://www.sau.com.au/forums/topic/126614-gtr-700/#findComment-2341853
From what I read/was told a while ago, the HKS car is substantially lighter than GTR-700. It is comprehensively stripped and is just the chassis, panels, motor and seat. It is even lacking alot of the safety gear ANDRA dictate GTR-700 must run which gives it another weight advantage.
https://www.sau.com.au/forums/topic/126614-gtr-700/#findComment-2342800
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
