Dont know just thinking out loud. Also isnt JUN just cosworth and they selling there own kits now?
is jun cosworth? umm no. Jun is Jun. funny that. Jun manufacture a huge range of products. for some makes of car they have cosworth make them blank piston forgings which they finish but other than that there is no other real connection.
put the joint down. :wave:
https://www.sau.com.au/forums/topic/126614-gtr-700/page/2/#findComment-2345113
  • 4 months later...
well i spoke to Mario the other day on another forum and he told me that he still owns GTR 700 and that he will get back into it sometime soon,also the car is exactly how he left it , he told CRD to run the car if they have time but obviously they havnt.
Its funny how many people think they know stuff about other peoples cars or maybe how much stuff they make up.
Edited by nismo 400 R N1
https://www.sau.com.au/forums/topic/126614-gtr-700/page/2/#findComment-2718069
  • 3 years later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
