Carl,
I believe it comes down to the competency of who's fitting the headgasket, I had my block decked as it was required to achieve the comp ratio I was after, the head was checked for straightness and it was apparently perfect so it was left as is.
I've had my cometic headgasket on for close to 2yrs and 45,000km's without a problem. Bl4ck32 has had his on for the same duration but slightly less kays and a heap of other blokes here in AUS run cometics without issues.
Saying that the bloke who machined and assembled out motors used cometic gaskets on everything, so clearly he knows the gasket. I too did a little search prior to approving the use of cometic headgasket and found lots of ppls had leaks etc.. He told me not to worry he knows what he is doing and never has had a problem using a cometic gasket. :D
Its most likely similiar as to having your engine builder recommend using a forged piston that he is familiar with then insisting he use forged piston on a brand he has no experience with... I do remember one case where one person did this and ended having a motor fail within a few hundred km's as the builder wasn't aware of a little pin securing quirk the pistons had.
I've attached a few pics of the surface finish.
agreed...the head and block have to be absolutely perfect for it to seal right with a cometic if it isnt then it wont seal worth a damn, mainly because since its mls composition it doesnt have the ability to fill small imperfections in the head and the block like the stocker.
i have heard of people spraying the cometic gasket, head, and block with copper spray a gasket to aid in sealing for those people who's head and block arnt quite up to snuff...
glad to hear your engine builder knows what to do, some do some dont.
Yeah i used copper spray last time i did my head gasket in the black skyline i had...
Its not cheap and was hard to find... (Only because most people had no idea what i was talking about when calling shops)
I have always used a little copper spray when doing a head gasket... I just its just what i was taught at tafe...
There is absolutely no problem with the Cometic gaskets. Like any MLS gasket, the surface finish needs to be spot on, any decent machine shop should be able to give you a suitable finish. Don't use any goo or spray on them, they have a viton coating which works better than any spray. A lot of the sprays will stop the viton sealing properly against the block and head.
No MLS gasket will seal properly if the block or head is not flat. You can file any high spots off if you are fitting the gasket in the car, use a straight edge and a feeler gauge to check. Most blocks will pull up slightly around the head bolt holes which you will need to rectify before fitting the gasket.
I've used cometic gaskets on engines making over 150Kw per cylinder without the gasket failing. I've also used one on an SR20 which detonated so badly it ate away the quench pads on the head and the alloy at the top of the bore but the gasket did not leak or even look damaged.
The ACL race series MLS gasket is made by Cometic, they won't put their name on anything they dont think is top of the line.
The story I've always had is that its best to have a fresh working surface on the deck of the head . I've almost always had the usual 3 thou taken off particularly if things got a bit hot . I believe it works because head gasket fire rings will compress slightly the head material when bolted down . When its time to replace the gasket there is a much better chance of it sealing if its flat . Should mention I used Nismo gaskets on the L and genuine gaskets on the FJ20 - never had any problems .
When the RB30 gets built I'm thinking of trying the brass rings with the fire rings removed from which ever is the apropriate gasket though this obviously would be difficult to do to an engine in situ . Don't know , depends on what sort of cylinder pressures its likely to run . I should do a search and see if Cometic or Nismo do a gasket to suit the 87.5 bore I want to run . If I get the CR/cams/turbo to my liking it probably won't need much more than mild boost to make the torque I want so maybe just a good conventional one will do .
Cheers A .
PS : A fello I used to know was using the brass ring system on FJ20's that were running 30+ lbs boost and cranking out around 720 Hp on Dave Handleys engine dyno without problems . Definatly super duty system ! This was a few years back though , don't know where he's up to now .
  • 2 years later...
anyone with anything?
I'm not sure if im in the right thread or what not but I have some issues with my R33 skyline with all the mods I have I am only putting 175.6 RWKW running on 8 psi boost, just spent over 2 thousand on it at a place i wish not to mention... never going there ever again. But here is a list
740 cc injectors
highflow turbo
greddy front mount
2.5" piping
bosch o44 fuel pump
power fc ecu
dump pipe
3" front pipe
3" from cat back
exhaust
Any ideas on WTF is going on would be appreciated as im getting seriously frustrated.
  • 2 months later...
A couple of years back valve guides went on my 33,head reco,so i thought i'll get a better head gas,got a acl tripple layer fitted,mechanic said to only run water for 1000 kays as they tend to leak if you put coolent in strait away,did this and put top coolent in then no leaks all good. :(
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
